tilt switch / fall switch location
Can anyone tell me where this is located please?
MattG#116
WIMP - Wales Is My Playground
Current bikes -
MattG#116
Current bikes -
- GregD-UK
tilt switch...
Hi all.
under your seat, if you stand on the left of bike right next to the edge of the petrol tank. Got a black and black with white wires on it ;)
Re: tilt switch...
Brilliant. Thank you. How do i know which way up it should be and if it is damaged? I have NIL experience with these....GregD-UK wrote:Hi all.
MattG#116
Current bikes -
MattG#116
Current bikes -
Re: tilt switch...
MattG#116
Current bikes -
MattG#116
Current bikes -
Thank you. I need to check this as i did wiggle it about yesterday to get battery in... hmmmm
MattG#116
Current bikes -
MattG#116
Current bikes -
- Firestarter
- Twisted Firestarter
Cheers, Much appreciated.Firestarter wrote:if you've got a multi-meter, you can measure the resistance across the switch - but I can't remember what it should be, but (and I'm sorry to do this, although Andy will be please) it has been covered and should be in the search results.
MattG#116
Current bikes -
MattG#116
Current bikes -
This will NOT be the cause of your starting but failing to run issues, the tilt switch cuts fuel supply so you will not be able to start at all.
You can completely rule out the switch by using insulation tape to make sure the sliding contact can't move across its bridge.
Sorry but look elsewhere, injectors,relays, fuel pump and related wiring.
I've spent many hours looking at fuel supply problems so feel free to ask
Thanks, I may take you up on that. I have ran out of patients with the bloody thing if I am honest. Just one thing after another. I don't use it enough to warrant issues. I like to go to a bike, push the start button, ride it - job done. The Falco fails to satisfy this simple expectation!fatboy wrote:This will NOT be the cause of your starting but failing to run issues, the tilt switch cuts fuel supply so you will not be able to start at all.
MattG#116
Current bikes -
MattG#116
Current bikes -
- Firestarter
no scottoiler on it. I have checked all fuel lines and will check again tomorrow hopefully. Weather allowing.Firestarter wrote:Vacuum lines? Got a scottoiler on it? Maybe the vac line has fallen off
MattG#116
Current bikes -
MattG#116
Current bikes -
will do. CheersAladinsaneuk wrote:vacuum lines are not part of the fuel lines....
look at ALL the hosing around the throttle bodies - not just what is coming from the fuel tank
MattG#116
Current bikes -
MattG#116
Current bikes -
