#2
by flatlander » Mon Oct 20, 2014 8:53 pm
You need to wash that muck off your screen :) or have you just run someone over?
#3
by blinkey501 » Tue Oct 21, 2014 4:58 am
Where is the hugger?
Falconihlist
#4
by Falconihlist » Tue Oct 21, 2014 5:16 am
In the cupboard Jay, going to try and fix the chips to the lacquer on the leading edge
Black is fastest!
wayno
#5
by wayno » Tue Oct 21, 2014 7:23 am
I love this bike, gutted I couldn't have got it :(
Falconihlist
#6
by Falconihlist » Tue Oct 21, 2014 8:52 am
Stuff done so far
Gabro chip
Forks reset
Front caliper half bolts
Front caliper mounting bolts
Tank bolts and spacers
Brake and clutch levers
New reservoir hoses
Upgraded reservoir lids
New reservoir hose clips
Throttle housing bolts
New master cylinder pinch bolts
Factory racing clutch slave
Tuono sprocket cover
Rear upper engine mounting bolts
New throttle cables
New left hand switch gear
Fitted fairing bolts and fasteners
Rear indicator LED bolt conversion (soldering by Nooj)
Skidmarx belly pan
Varta TTZ battery
Uprated starter solenoid.
GPR high level exhaust
Rear caliper mounting bolts
Darker model rear light surround
New jubilee clips on coolant hoses
ECU cover
Still to do
Hooked airbox
Front and rear axle nuts
Front LED indicators
57mm TB's
Engine cover bolt kit
Wish list
Radial fork conversion
BST wheels
Black is fastest!
TwinkietheKid
#7
by TwinkietheKid » Tue Oct 21, 2014 5:32 pm
Falconihlist wrote:
Bloody hitchhikers are getting aggressive ain't they? Considering you have to get home before you can scrape 'em off!
'03 Falco, in the fast colors
'15 Caponord, look upon my toy, ye Mighty, and despair!
Frenzies bewilder, reveries perturb the mind.
- Wear the Fox Hat
#8
by randomsquid » Wed Oct 22, 2014 4:53 pm
I'm jealous, nice bike and it even has a fairing nooj. All I get is spiders.
Falco Frank
#9
by Falco Frank » Wed Oct 22, 2014 8:10 pm
THAT is a cracking piece of design and vision.
Well done.
nicketynoo
#10
by nicketynoo » Thu Oct 23, 2014 1:01 pm
That is a cracking bike and lovely paintjob. when I stare at it from the side view I can't help thinking something is missing. Its not much but possibly just needs something to lift the wheels, could be needs them in a different colour or even something as simple as some thin white rim tape
But is still 1 very eyecatching piece of kit
I don't care if you lick windows,
Take the special bus
Or occasionally pee on yourself.
You hang in there sunshine, you're special!
wayno
#11
by wayno » Thu Oct 23, 2014 1:32 pm
I'm not that keen on rim tape, but I agree a white rim tape strip might bring out the wheels slightly.
Not slating the bike at all, I love it anyway.
Smilinjack
#12
by Smilinjack » Fri Oct 24, 2014 5:15 pm
Without wishing to come over as a pedant, strictly speaking it should be
bianco nero. Blanco is Spanish. Doesn't make the bike any less nice mind.
Falconihlist
#13
by Falconihlist » Fri Oct 24, 2014 7:41 pm
Smilinjack wrote:Without wishing to come over as a pedant, strictly speaking it should be
Nothing wrong with that
I only opted for that because I was being lazy,and didn't want it to sound like a drink
Black is fastest!
#14
by flatlander » Fri Oct 24, 2014 8:27 pm
Unless of course he was using Nero as a noun in which case it would be fine ... Just saying like ;)
