Mille Cams, Clutch slipping and Rear lights (not working)
Went for a ride out with my Dad yesterday, great ride through Midlands (I think.... lol) Few questions I have as a result of this ride -
Miile Cams (?) - the previous owner (who had the bike for only a few weeks before taking dislike) explained that the Owner previous to him had put the Mille Cams in the Falco. I dismissed the subject to be honest. However, riding yesterday I noticed just how hard the Falco pulls and how it just continues to pull. My Dad has the 2000 Hayabusa (full power) and at one point we stopped and he just could not work out why he could not outpace the Falco, straight-line acceleration that is. This got me thinking about these Cams that may/may not have been done.
1. Can the Mille Cams be fitted to Falco?
2. Could I find out without stripping Engine?
3. I have no Dyno readout etc. to say what power she is pushing out, having owned Blackbirds etc. and ridden 2x 'Busa's, this Falco is no Moped!!
4. I have noticed a definite increase in power, smoothness etc. since putting after market pipes on. I do not know what filter it has.
5. Almost 40k on clock.
Clutch Slipping - When the Falco is given full throttle (whish isn't really needed) in any gear the RPM will shoot up and although pulling hard seems as if the Clutch is slipping, either that or the back wheel is spinning up?? 1/2 or 3/4 throttle, no slip.
1. Is there anything I can try prior to getting new clutch plates etc.
2. Would bleeding help?
Rear Lights - Trivial one, but my rear lights have stopped working, when headlight or side lights on. Brake lights work fine. Obvious answer is the bulbs, but to me seems unlikely they would both blow the tail light at same time.
1. Common thing with Falco?
2. Being Italian, I thought I would ask before I go in there with a Multi-meter.
[/b]
[/b]
MattG#116
WIMP - Wales Is My Playground
Current bikes -
MattG#116
Current bikes -
Re: Mille Cams, Clutch slipping and Rear lights (not working
YesMattG#116 wrote:Went for a ride out with my Dad yesterday, great ride through Midlands (I think.... lol) Few questions I have as a result of this ride -
However, which year mille are you talking about? Falco cams are the same as the earliest Mille.
Falco pulls like a train anyway. In the real world there's not much to choose between them performance wise. Falco a bit better down the bottom end and the Mille at the top end (where it's not a great help on the road)
Probably not .... well the cam covers would have to come off and then you'd not be able to tell by just peering at themMattG#116 wrote: 2. Could I find out without stripping Engine?
Indeed. Power will not give huge numbers, the fun is in the deliveryMattG#116 wrote: 3. I have no Dyno readout etc. to say what power she is pushing out, having owned Blackbirds etc. and ridden 2x 'Busa's, this Falco is no Moped!!
They do like to be allowed to breath. Less restricted cans and airkit certainly helpMattG#116 wrote: 4. I have noticed a definite increase in power, smoothness etc. since putting after market pipes on. I do not know what filter it has.
Run in then ..... should be plenty of miles left in it as long as it's been looked after properlyMattG#116 wrote: 5. Almost 40k on clock.
I'm guessing it's a red or a black one - their clutches are not so robust. Don't use fully synthetic oil with themMattG#116 wrote:
If all else fails Aprilia has authorised 10W40 oil to be used .... and if that fails, some have done the trick of roughening the clutch steels
Not a common problem. Just a case of checking bulbs and wiring (TBH there are few common problems)MattG#116 wrote: Rear Lights - Trivial one, but my rear lights have stopped working, when headlight or side lights on. Brake lights work fine. Obvious answer is the bulbs, but to me seems unlikely they would both blow the tail light at same time.
[/b]
- TwinkietheKid
Is there any free play with the clutch lever? If not, the clutch is being prevented from fully engaging perhaps?MattG#116 wrote: Clutch Slipping - When the Falco is given full throttle (whish isn't really needed) in any gear the RPM will shoot up and although pulling hard seems as if the Clutch is slipping, either that or the back wheel is spinning up?? 1/2 or 3/4 throttle, no slip.
'03 Falco, in the fast colors
'15 Caponord, look upon my toy, ye Mighty, and despair!
Frenzies bewilder, reveries perturb the mind.
Thanks for the replies. I will check it all out.
I just cant believe it took me this long to get a V-Twin!! Incredible bit of kit!
MattG#116
Current bikes -
MattG#116
Current bikes -
As far as the clutch goes, mine is fine for genteel, frock wearing side saddle riding but will slip like fuck when ridden in hooligan mode.
I bought some EBC frictions hoping this would cure the problem.... NO, they dont fit and sit proud of the clutch basket so slip like fuck all the time, can be rectified by fitting one less friction and plain plate but that is 10% of the clutch gone.
I put the prilla plates back in, same story for more than a year !
A Falc in the right hands is quite good at surprising jap 4 pilots so good work that man
- slickliner6
He obviously wasnt trying pmsl.MattG#116 wrote: My Dad has the 2000 Hayabusa (full power) and at one point we stopped and he just could not work out why he could not outpace the Falco, straight-line acceleration that is.
[/b]
Tell him the throttle will go a little further round.
Lol, I give him enough grief as it is. To be fair the Busa is a beast and whilst the Falco will keep with into the early 100's, the Busa then comes alive and keeps pulling at just about the same rate ...slickliner6 wrote:He obviously wasnt trying pmsl.MattG#116 wrote: My Dad has the 2000 Hayabusa (full power) and at one point we stopped and he just could not work out why he could not outpace the Falco, straight-line acceleration that is.
[/b]![]()
Tell him the throttle will go a little further round.![]()
MattG#116
Current bikes -
MattG#116
Current bikes -
SO it seems like its a live with it situation or start fiddling?fatboy wrote:As far as the clutch goes, mine is fine for genteel, frock wearing side saddle riding but will slip like fuck when ridden in hooligan mode.
MattG#116
Current bikes -
MattG#116
Current bikes -
It's a case of checking what oil you've got in there and if it's still happening with suitable engine oil, maybe roughen the clutch steels (have a search on the forum for those that have done this).MattG#116 wrote:SO it seems like its a live with it situation or start fiddling?fatboy wrote:As far as the clutch goes, mine is fine for genteel, frock wearing side saddle riding but will slip like fuck when ridden in hooligan mode.
Also check the free play in the clutch actuation as Twinkie suggested.
I've had the same problem running on both 15/50 and 10/40 semi synth, the steels dont appear to be warped when stacked on top of each other and viewed by eye, no air space between em (yes they were oil free ).
Griff opined that the steels rarely cause problems unless they are warped.
I looked at roughing the steels (AF1) but that seems to be a temporary fix, I have EBC heavy duty springs fitted, not checked the actuation free play, will do when I fit new slave cyl, when it stops raining
Well I was getting slippage in the higher gears at high revs once she was nicely warmed up. I asked the shop I bought her from and they had used full synth to service her. So I dropped the oil and fitted a new filter and some semi synth Motul 5100 4T 15W-50 from opie. I also roughened up every friction plate with an orbital sander and added a washer to three of the springs.
Result has been zero slippage for a slightly heavier clutch and occasional rare difficulty in finding neutral BUT much bigger smiles all round! Worth a shot.
Mines a 2001 in red (now faded to a flip flop orange)
