PCBs ..... just for us!
#1 Post by D-Rider » Tue Jul 29, 2014 9:21 am
Well not sure whether to post this in here, general chat, "geeksville" or wherever .....
..... they've now developed printed circuit boards designed to deal with the harsh environment that we subject ourselves to .... read on ....
http://www.electronics-eetimes.com/en/r ... 87&vID=209
EE Times Europe wrote:Rigid-flex PCB meets tough motorbike requirements
July 28, 2014 // Christoph Hammerschmidt
A printed circuit board technology especially for sport motorcycles? Sounds weird, but this type of vehicle lays down particularly tough requirements to control electronics - extreme mechanical load changes, heat, vibration, humidity, to name just a few. Along with GCD-PCB Design GmbH, PCB manufacturer Würth Group has developed a rigid-flex PCB that meets these requirements.
In electronic systems, mechanic joints are particularly vulnerable to the effects of load changes and vibrations. Typically, this effect hits at soldered wire connections - they tend to break under mechanical stress, which often enough leads to the complete failure of the respective ECU. Rigid-flex, on first sight a contradiction in itself, is the solution: It consists of two or more rigid PCBs with a flexible sheet of polyamide as the connection between them; the polyamide sheet carries conducting paths made of copper. Besides enabling the PCBs to withstand the vibrations, it helps designers to better exploit the available space.
Though rigid-flex PCBs appear to have a cost disadvantage at first sight, the contrary is true, claims Jürgen Kintopp, general manager of GCD-PCB: It makes a number of small parts redundant, such as connectors, cables, and screws. In addition, the higher reliability and robustness compensate for these extra costs. And, of course the technology is not restricted to sport motorbike applications - it can also be deployed on any environment with hostile character.
#2 Post by DavShill » Wed Jul 30, 2014 8:46 am
You clever people, I have no idea what this means but it must be good if Andy says so :smt002
GregD-UK
PCB's...
#3 Post by GregD-UK » Wed Jul 30, 2014 11:41 am
As always, quality and improvements cost money! My ride has had a couple of bounces, so, I can say up to now has resisted high impact and vibration. When I stripped it to get the frame coated, I did notice some love-rash. So, the original are quite robust.
Can understand this use in off-road and race applications. The latter has money in the pot.
