Front brake light switch spare anyone?
Been told by a couple that one of my rear light bulbs is out. Finally got round to fitting a new bulb only to realise that the brake lights are permanently on. It appears that the front brake light switch is fkd. So before I remortgage the house to buy a new one, has anyone got one kicking around surplus?
By the way I had to take the fairing off which is about 100 fasteners, to disconnect the brake light switch. Just confirms that I'm not a patient man, felt for a while like using a hammer rather than a selection of allen keys.
i bought one of those really cheap electric screw drivers from aldi/lidl - 10 quid iirc... makes undoing all those posy allen keys a tad easier....
i checked and do not have a spare switch
Re: Front brake light switch spare anyone?
I could take one off the track bike keith.HisNibbs wrote:Been told by a couple that one of my rear light bulbs is out. Finally got round to fitting a new bulb only to realise that the brake lights are permanently on. It appears that the front brake light switch is fkd. So before I remortgage the house to buy a new one, has anyone got one kicking around surplus?
If you don't have a headlamp then maybe you wouldn't need to dismantle half the bike to unplug it? If its not much trouble and you don't need it, then I'd be happy to take it. Does £10 seem about right? Else I can try and source one this week.blinkey501 wrote:
I had a very similar issue about 5 years ago. If it's anything like the Futura's, and if you have the patience and sufficiently nimble fingers and very good eyesight (or reading glasses), you can dismantle the switch, fettle its innards, and reassemble. I did this - I can't remember now exactly what the problem was - something sticking - but it's been fine so far.
Fairing off keith. Pm me your addressHisNibbs wrote:If you don't have a headlamp then maybe you wouldn't need to dismantle half the bike to unplug it? If its not much trouble and you don't need it, then I'd be happy to take it. Does £10 seem about right? Else I can try and source one this week.blinkey501 wrote:
Are there any more switches going spare?
Or else does anyone have a link to the cheapest replacement of whatever bike happens to use the same one...
As for fitting I think I'll cut the existing wire and solder it on.. it looks like fishing for the connector is far too much work..
Insert humourous comment here
Connector is at the fairing frame just behind and towards the top the instruments. You might be able to weave your hand in and get to it but I took the fairing off. I wasn't sure whether there was a connector there or the cable dived into the loom to appear some where else.
- Falconihlist
- Falconihlist
