Doh! ..... drip drip drip
Home from work, just parking the Falco and my son says "what's all that coming from your bike?"
Ah, that'll be a coolant leak then.
Typically happens when I've only just filled brim full of fuel - so even lifting the tank will be just that bit more of a pain as it'll need draining a bit first.
Think I know what the weekends tasks will include ......
Doh !
Ah well it'll be much much better than being at work.
Doh !
I think it's either the 3-way manifold or one of the hoses that connects to it.
Pulled the plastics off tonight to save a bit of time tomorrow and having a quick squint again does suggest it's from that area.
Yep it's the 3-way manifold - leaking once the thermostat opens.
Now to search to see whether I've got one squirrelled away .....
Then the fun begins squeezing in to replace it behind the frame rail and the thickest bit of wiring harness on the bike
- TwinkietheKid
Been there, done that.D-Rider wrote:Yep it's the 3-way manifold - leaking once the thermostat opens.
Patience and skinny fingers are your friend!
'03 Falco, in the fast colors
'15 Caponord, look upon my toy, ye Mighty, and despair!
Frenzies bewilder, reveries perturb the mind.
Well I don't have a spare so I can use the time in waiting for one to arrive from ebay to let my fingers slim down a bit!TwinkietheKid wrote:Been there, done that.D-Rider wrote:Yep it's the 3-way manifold - leaking once the thermostat opens.
UPDATE:
Fingers may have a long time to slim down as ebay seems to only have them for GenII RSVRs/Tuonos. They are a different part number so don't really want to risk it and find myself back to square 1.
If anyone has a spare one (for a Falco, Futura, GenI Mille or Tuono) that they would be willing to flog me then please let me know ..... I want the bike back on the road!
It's part number 4 in the pic
FURTHER UPDATE:
All Sorted
With just one further poke about I found that one of the hose clamps (those ones that Aprilia use instead of jubilee clips - the ones that don't come undone easily) - number 5 in the picture above - was really loose !
Using greater dexterity than a gynaecologist getting into that really tight space, I managed to remove the clamp and replace it with a real jubilee clip.
Ran it up to temp, a couple of cycles of the fans, no more leaks. Job sorted.
While the bike's apart I'll do a few more jobs .... have already removed the PCIII which has just sat disconnected since fitting the Gabro chip.
- TwinkietheKid
Oh no! That is the easy 3-way! I was thinking it was part #1 in the picture. That one I've had crack. It's a blast to replace!D-Rider wrote:Well I don't have a spare so I can use the time in waiting for one to arrive from ebay to let my fingers slim down a bit!TwinkietheKid wrote:Been there, done that.D-Rider wrote:Yep it's the 3-way manifold - leaking once the thermostat opens.
UPDATE:
FURTHER UPDATE:
All Sorted![]()
Been there, done that. And yes,it's a bastard to get to.TwinkietheKid wrote:Oh no! That is the easy 3-way! I was thinking it was part #1 in the picture. That one I've had crack. It's a blast to replace!
..... and I wish it was .....HowardQ wrote:Glad it's sorted!
Came to start it this morning. It ran as rough as a badgers arse for a moment and stopped.
I'm wondering whether I trapped a fuel line in the fight to get the swollen tank back in place, whether there is a bit of a wiredness with the sidestand switch (was a bit dodgy and I've been looking for a replacement) or whether the tip over switch was a bit "confused" after I'd popped it bak in place after fighting the tank back in place.
.... I'll have to start exploring .... though a lot of other jobs to do in the evenings this week ...
Well this is an odd one.D-Rider wrote:..... and I wish it was .....HowardQ wrote:Glad it's sorted!
I'm wondering whether I trapped a fuel line in the fight to get the swollen tank back in place, whether there is a bit of a weirdness with the sidestand switch (was a bit dodgy and I've been looking for a replacement) or whether the tip over switch was a bit "confused" after I'd popped it bak in place after fighting the tank back in place.
Came home tonight (via the car
Thumbed the starter to see whether there were any signs of life ..... and to begin with there was nothing. Then it grumbled into life ... making some funny sounds before deciding it would run as a 500cc single attached to a 500cc compressor.
After a while the other pot chimed in and it started warming up nicely ..... and after a short while was running as sweet as a nut.
Left it running for quite a while and it just ran really nicely - picking up really well on the throttle.
Tomorrow's commute will confirm whether it's really OK but it seems to have self-healed !
Odd - but far better than having to rip it apart and start diagnosing ..... hopefully !
