D-Rider wrote:robbier6 wrote:I'll whack a multimeter over it later and see what we get volts wise..battery is probably 2 years old
Open circuit volts will tell you very little - you need to check the voltage under load.
Other possibility is poor connectivity in the starting circuit - corroded terminals, bad earths etc
I'll second this, almost certain to be a problem in this area if you only get clicking noise problems, (
Fatboy's comments are exactly right about the noise of a shot sprag), it can often be just battery leads, if it is just clicking.
I once started the bike OK after standing for a few weeks, started it again after I'd got it out from the garage, I started it again after a petrol stop.
Stopped to clean my visor in the middle of a run out and just clicking noises when I hit the starter. Thought it must be something serious as has been starting fine before, I just tweaked the battery terminals up a bit and hey presto.
If that does not work, check all the rest and then the solenoid itself.
