Falco/Futura Engine bits
cmdrew
#1 Post by cmdrew » Tue Jun 17, 2014 8:57 am
After having to perform a couple of engine swaps I find myself with a couple of old engines sat in my garage which I am going to break for spares.
The Falco engine was run low on oil apparently so crank/pistons/barrels are probably scrap but I do have such things as casings, gears, clutch, generator, starter clutch etc available.
The futura engine is mostly complete but I tried to swap over the front cylinder cams for the Falco items and ended up scoring the cam bearing in the head as the cams had been damaged. Again though all other bits are available at the moment.
If anyone has a need for any engine bits please drop me a PM and I will see what I have. I haven't heard either engine running obviously but I can't see why all of the ancillary parts shouldn't be fine.
