Cooling fans not coming on
Well finally got my engine in and running having had to replace a number of items such as the camchain tensioners and neutral switch.
It does seem to rattle quite a bit from the clutch which goes away if you pull the clutch in. I'm used to this on a Ducati but I'm not sure if the Aprillia normally has this clutch rattle as it is a wet clutch?
I'm also finding that the fans are not cutting in. They are both wired up as far as I can see but I have had the temperature readout up to 104 degrees and the fans did not cut in - I understood that they should cut in at 100. Checked the fuse and that's OK but I find it hard to believe that neither is working so would welcome any suggestions.
The coolant tempsensor ( I think ) lives in the manifold by the thermostat. Check you have voltage to the switch and terminals are free of crud.
There is also a fan relay whih may be the culprit, very small possibility the thermostat may not be opening, if this is the case you will be overheating very quickly and the rads will be cold to touch.
As Zoidberg said, when you brige the two terminals of the fan swich connector and fans kick in then the temp switch is shot.
This project hasn t been easy on you !
Really odd - I have found the wires for the fan switch and bridged them and the fan comes on so all good there. Unfortunate
Y the wires are not connected up (and weren't when I replaced the engine) and I can't find anywhere to plug them in to!
The manual suggests that the switch should be in the 3 way coolant manifold on the left hand side of the engine but mine just has a bolt there - no switch. Any where else the switch could be or has it just been removed at some point on my bike?
Re: Cooling fans not coming on
Yes, this is entirely normal for a falco. Nothing to worry about.cmdrew wrote:It does seem to rattle quite a bit from the clutch which goes away if you pull the clutch in. I'm used to this on a Ducati but I'm not sure if the Aprillia normally has this clutch rattle as it is a wet clutch?
I replaced the bearing and its just as noisey !Dalemac wrote:Yes, this is entirely normal for a falco. Nothing to worry about.cmdrew wrote:It does seem to rattle quite a bit from the clutch which goes away if you pull the clutch in. I'm used to this on a Ducati but I'm not sure if the Aprillia normally has this clutch rattle as it is a wet clutch?
Reviving an old thread, as when I came to fire the red Falco up after some work, the temps went up to 101-102 deg C and the fans never came on. Normally they kick in at around 95 C.
So first step is to bridge the two contacts on the switch bolted to the 3-way manifold, I take it? This effectively tests out the relay, I presume. And, assuming the fans do come on when the contacts are bridged, if the fans don't come on after that when the engine is up to temperature then the switch itself is toast?
Nice one, thanks for that. I have a suspicion that one or both of the spade terminals may have been disturbed, as Griff's chaps fitted one of their air kits recently, but can't check as the bike is 70 miles away. That's the hope, anyway. Replacing the thermal switch will be a nuisance I could do without.
Thanks for the part number - appreciated.
