Briggs & Stratton powered Falco
- KitchenSync
With everything in place and an uncrushed fuel line installed - Signor Falco reliably runs terribly.
Whilst this 2003 RSV engine is running stock Falco electronics, I can't believe that the 125 learner bike levels of performance are purely down to mapping. I'm totally unequipped for balancing the throttle bodies - and funds have run out to either get tooled up to do so or to get it to Griff for a sort out.
If you've any clues as to what I can do to clean it up a bit until I can get a Gabro and a tune-up I'd be grateful. It's very sluggish in pickup, won't tick over, pops, bangs and has the ill-favoured odour of an engine running very rich.
I'm delighted that the engine runs though and that for the first time in 3 years I'm not greeted every morning by puddles of oil and the front and rear of the engine!
https://www.youtube.com/watch?v=VUpa75ZQxYI
Have you set up your fast Idle Control properly - and checked your TPS?
Workshop Manual explains how.
Not suggesting that's your only issue but to get it to start and warm up would be a good start.
Battery sounds like it needs charging (or is at the end of it's useful life)
- KitchenSync
- KitchenSync
- flatlander
Check oil level and plugs chick redex or the more manly version whose name escaped me through at least once. Match the EXU to the engine and check connections. If your ECU was set for a gabro etc check strings and there is a second throttle screw setting under the tank
- KitchenSync
- KitchenSync
- KitchenSync
- flatlander
As an aside my Briggs and Stratton powered lawn mower is running very well especially considering the lack of care it receives but don't tell squid he"ll be jealous
When I couldn't get my bike to start (because it was a future engine withe wrong generator) there was really no life at all so I doubt that is your issue. Other than the obvious such as checking the sensor on the air box is plugged in and that all coil leads are seated correctly, the only thing I had which was similar was when the cam timing , well actually the cam ignition timing was out and the bike would start just but ran terribly coughing spitting, back firing you name it. If all else fails May be worth checking.
Set the engine on tdc front cylinder and make sure that the IN and EX on the cams point to each other. If so the cam timing should be fine on that cylinder at least. Now if you can take a look at the exhaust cam. There is a raised section on the back face of the sprocket which should be under or very near at least to the cam sensor as this is what triggers the ignition. On mine this was at least 120 degrees away so was easy to spot that it was wrong. As I said though mine had the wrong engine in it so I doubt this would be true of your engine assuming it is from an rsv. Did you check the code on the rear of the engine?
- flatlander
- KitchenSync
- KitchenSync
Chumptastic
Throughout my life I've been hampered by a tendency to make assumptions and when things go wrong, look for the complex answers first.
Having ridden the bike 12 miles - chugging along thinking "this is exactly like it's running on one cylinder"...
I'd felt the gases from each can - both warm, seen blue flames from each can. Duh - they're connected aren't they! Got to my destination, reached down and unplugged the leads to the rear cylinder... No difference whatsoever! Bike carried on chugging away. I've not got tools here to get at anything to see what's not connected or broken but please PLEASE let me learn to look for simple solutions next time!!!
*shameface*
*shameface*
