Uneven braking
spiderwheels
Uneven braking
#1 Post by spiderwheels » Mon May 05, 2014 9:16 am
Good morning lads and lasses,
My front brake feels uneven. I can feel it gripping and releasing pressure very subtly. Is it possible the floating discs aren't floating?
#2 Post by D-Rider » Mon May 05, 2014 9:35 am
Yes - give your bobbins a good clean. Stick a bolt through the hole and tighten a nut on to it. this will allow you to turn it while you squirt in the brake cleaner.
Repeat for all bobbins.
Time consuming but usually does the trick.
If not, probably pad material deposition.
spiderwheels
#3 Post by spiderwheels » Mon May 05, 2014 9:45 am
Thanks. What's good brake cleaner?
#4 Post by randomsquid » Mon May 05, 2014 10:59 am
spiderwheels wrote:Thanks. What's good brake cleaner?
I just tend to buy whatever is available locally, at work they used to use Wurth stuff which has a good rep.
I bought a can of Winn branded stuff from Halfords recently. Worked like brake cleaner normally does but came out of the can with an impressive blast.
#5 Post by flatlander » Mon May 05, 2014 12:33 pm
The welsh outfit that does wavy discs has some good info on this sort of thing can't recall their name though despite having the discs probably black dragon or something like that??
#6 Post by D-Rider » Mon May 05, 2014 1:19 pm
Last lot I got was either from Aldi or Lidl ....... trouble is they only stock it occasionally
Midnight Rider
#7 Post by Dalemac » Mon May 05, 2014 3:16 pm
As D-Rider said, Aldi/Lidl sell it occasionally. If I really need it I will buy it off amazon or ebay as it is cheaper.
#8 Post by blinkey501 » Mon May 05, 2014 4:00 pm
flatlander wrote:The welsh outfit that does wavy discs has some good info on this sort of thing can't recall their name though despite having the discs probably black dragon or something like that??
Black shadow? :smt017
#9 Post by flatlander » Mon May 05, 2014 5:32 pm
That's the one :)
spiderwheels
#10 Post by spiderwheels » Sun May 11, 2014 8:08 am
I finally got around to getting some brake cleaner in there. Wow, gold discs.. who knew? :)
spiderwheels
#11 Post by spiderwheels » Sun May 11, 2014 4:33 pm
hmmm.. well cleaning the discs up seems to have made it worse.
#12 Post by Aladinsaneuk » Sun May 11, 2014 4:38 pm
did you do the bobbins?
examine the pads
spiderwheels
#13 Post by spiderwheels » Sun May 11, 2014 4:48 pm
Yes I did all the bobbins.. none of them seemed seized. I'll pop the pads out sometime in the week
#14 Post by fatboy » Sun May 11, 2014 6:46 pm
When you have the calipers off,peel back the rubber dust seals and look for corrosion on the brake pistons,
Use a thin bit of wood in place here the disc would be,operate the brake ,both pistons should move freely and at the same rate.
Also check the pad retaining pins are not too ccorroded,preventing the pads from moving
#15 Post by D-Rider » Sun May 11, 2014 10:13 pm
Could be material deposition if the pads were not bedded in correctly: http://www.stoptech.com/technical-suppo ... ther-myths
