ok - next week.....
ok - next week.....
#1 Post by Aladinsaneuk » Tue May 15, 2007 10:25 pm
well, am thinking of doing this next week so, some guidance please
I have a standard mille swing arm, lovingly polished and ready to go - ish
I have all the mounting plates, and i do have a white spring shock already
now humour me, as i need to ask these questions
the swingarm has the rubber bush/bearings in it and all seems good there BUT - I only have the rod/bar/bolt on my falco, not the one off the mille - so do i have to change that?
am i correct in thinking that all i have to do is remove my old swing arm, split and shorten my chain, fit the mille swing arm, and refit the chain?
reason why I am asking all this - i NEED to have the bike good to go with in 48 hours of starting the job and just need a few pointers to ensure mr fuckup does not come to visit.....
cheers in advance [/b]
#2 Post by Gio » Tue May 15, 2007 10:29 pm
PM Falco9 he's done it :smt001
Wot-bike-isit
#3 Post by Wot-bike-isit » Wed May 16, 2007 4:08 am
I had a bare 01 RSV arm, just the arm no bearings no nuthin. Everything on my falco arm went right into the rsv one no problem.
But if I were you I would let the job wait until after what ever happens in 48....I spent a entire weekend doing it.
And I would just replace your chain. I think it needs to get longer rather than shorter.
Go here for some help http://apriliafalco.info/index.php/falc ... ins_shock/
________
Ford Pinto engine history
Tweaker
Main bike: BMW R1250RS
#4 Post by Tweaker » Thu May 17, 2007 10:49 am
The swap is straightforward but you'll NEED a 3/8 or 1/4 drive socket set with a universal joint to reach the upper rear header nut. (1/2"" is too big and won't fit). Don't remove the nuts, just loosen them to give some wriggle room. If you've got a 15T front sprocket, the standard chain will fit, just get a new soft link. The Falco swing arm pivot rod fits the Mille arm. It helps if you can get hold of a tool to undo the castellated nut on the pivot rod - a 'Shimano Freewheel removal tool' from a decent bike shop will do the job nicely and costs around 4 quid - much better than a hammer and screwdriver :smt018 . It has 4 'dogs' round the circumference which fit the nut. Once the arm is on, you may need to slacken the banjo on the rear calliper and turn it to line up with the arm - the brake line is only just long enough! Other than that, it's just nuts and bolts. Get the back of the bike as high as you can to give yourself plenty of working space. The job took me just over 4 hours, including cleaning a greasing everything along the way.
HTH
Tweaker
TwinNut
#5 Post by TwinNut » Thu May 17, 2007 11:59 am
Tweaker wrote:It helps if you can get hold of a tool to undo the castellated nut on the pivot rod - a 'Shimano Freewheel removal tool' from a decent bike shop
:smt053 Dave, I haven't lost it, I'm just waiting for a garage to be built in which to house my bike and it's new swinger.......which should be soon if the builders pull their bloody fingers out!!
Syltiz
Chaos Merchant
#6 Post by Syltiz » Thu May 17, 2007 12:15 pm
I have been meaning to do my swingarm mod for about 9 months now.
Hmmm... maybe this weekend is the one for me too!
Tweaker
#7 Post by Tweaker » Thu May 17, 2007 7:51 pm
Don't worry Simon, I wasn't having a dig - in fact, I'd forgotten you had it :smt017
Sounds like you've got a lot going on at the mo' though :smt045
Tweak
falcomunky
#8 Post by falcomunky » Thu May 17, 2007 8:52 pm
Tips n things to avoid can be found ere...
http://www.jahlis.net/ars/viewtopic.php ... 8bcc90cb8e
Two is the magic number... ;)
