This philosphical question is brought about by the discussion TLoML and I had last night.
She is saying that the Aprilia engine designers designed the engine to run at an optimum temperature range, somewhere between 75 degrees C (where the thermostat opens) and 95 degrees C (where the cooling fans kick in), and that by changing the fan switch to a lower temperature I will be reducing the engine's optimum temperature range. With the effect that the engine may not run as well as the engineers designed it to.
I want to change the fan switch because I don't like the idea of the engine running very hot before the fans switch on. I can recall that engines prefer to run cooler than hotter, and that engines can be damaged by running too hot for too long.
Given that the riding I do is mostly low speed commuting, I'd prefer to keep the engine cooler - especially on hot summer days where the ambient air temperature can be 35 degrees C or higher. (As an aside, it's been a fairly cool 15 degrees C some mornings and the engine temperature can still get to 95C and stay there for quite some time.)
So, who is right here?
To be fair - I haven't seen any posts (either here, on ARS or AF1) saying that the stock fan switch is too hot and will cause engine damage in the long run, but I have seen posts on AF1 from people saying that they've installed the lower temperature switch out of personal preference.
Finally, I heard that the early Falcos had the low temperature switch but changed to the high temperature one somewhere in the middle of the production run. Whilst the RSV-R started with the high temperature one and changed to the lower temperature switch. Is this correct?
If you've read this far, you deserve a medal!
Cheers!
