starter sprag clutch
#1 Post by fatboy » Fri Feb 07, 2014 7:45 pm
Ok, horrible noises on start up lead me to believe Im in the market for a new one, so simple question.
Is there an uprated version or just buy standard ?
Ta Paul
#2 Post by blinkey501 » Fri Feb 07, 2014 8:04 pm
They don't do an uprated aprilia version. Although the KTM might be. But a topped up battery will be the best solution to any uprated version.
If you are struggling with changing it pm me for my phone number :smt002
Or alternatively bring it to me with all the parts and I will do the job which will be a couple of hours. I want to take more detailed photo's of the task for our technical section.
#3 Post by fatboy » Fri Feb 07, 2014 8:16 pm
Thanks mate, got no worries about swapping it out, thanks to your spot on posts.
I will take pics of any nasties I find, thanks again for the offer of help, ' youre oop there, Im down by yer !
#4 Post by blinkey501 » Fri Feb 07, 2014 9:00 pm
Make sure you get the correct Loctite :smt002
#5 Post by fatboy » Sat Feb 08, 2014 6:34 pm
Two questions I cant find the answer to..
Correct Loctite grade ?
What size hex bit do I need (to buy ) ?
edit
Found eventually in my OCR download which I cant search...
16mm hex bit
Loctite 648 green
KitchenSync
#6 Post by KitchenSync » Sun Feb 09, 2014 11:26 pm
I bodged mine - just clipping 15mm or so out of the floppy spring. It's been good for over a year now. I knew the engine was a goner anyway so was prepared for a short-term fix.
#7 Post by D-Rider » Mon Feb 10, 2014 12:48 am
KitchenSync wrote:I bodged mine - just clipping 15mm or so out of the floppy spring. It's been good for over a year now. I knew the engine was a goner anyway so was prepared for a short-term fix.
Yeah - that's the fix that Pierre pioneered. His write up is still there in our Aprilia Ridersite Archive: http://www.jahlis.net/ars/viewtopic.php ... ade28a1f05
Certainly seems to be a viable option for those on a budget or needing a quick fix without waiting for parts to arrive.
Good to hear of another for whom this has worked well.
