BikerGran wrote:We bought a new telly cos it was going cheap in Sainsburys - haven't a clue how to set it up!
It's a 32in HD ready LED TV
Says it's HD Ready 720p
The 32in is the size in old-fashioned imperial units (as still used in the US of A) - It's a measurement across the screen diagonal
HD ready means it's not Full HD - it's a lower resolution screen ..... confirmed by the fact that it is 720p
BikerGran wrote:
2 x HDMI
PC Input
It has 2 HDMI inputs ..... these are the new-fangled input connections that you use with things like DVD players and Freeview boxes etc
In the past you might have used SCART connectors but modern stuff uses HDMI digital connections (don't get me started on HDMI DRM .....)
For example you can connect your DVD player to one HDMI port and your old Freeview recorder on the other .... assuming they have HDMI outputs.
Modern ones will (though some of the ones I have at my house don't)
BikerGran wrote:
Freeview
It has a Freeview tuner/decoder built in
BikerGran wrote:
What we didn't think ofn at the time was that we currently have a Freeview Plus box so we can record programmes. New TV doesn't have that facility and neither does out DVD player.
Been told that we can use it with our olod Freeview Plus box for recording - but how will that work as the TV already has Freeview?
Yes as I said before you can connect it to one of the HDMI inputs (provided the freeview recorder has an HDMI output)
You will just have to switch the TV signal source to the appropriate HDMI source (input) to use the external box.
Therefore for just watching freeview you can use the tuner in the TV and at the same time you can record something else (or the same thing) on your old recorder box
BikerGran wrote:
Really don't want to have to pay someone to come and do it - might have to get 16 year old grandson down here but he lives 40 miles away........
Any thoughts for us ancient Luddites?
You could move nearer to him or make him move nearer to you .... that's the only thought on that one!
