Tonyunn
#1
by Tonyunn » Sun Jan 05, 2014 3:16 pm
can I get a tube put into a tubeless tyre, I have had both front and rear tyres changed but I am still losing pressure at the back so I guess the rim might be leaking somehow.
the fitter did check it and didn't tell me there was anything wrong with it.
Speed Blue SL 1000 Falco
stumblebum76
#2
by stumblebum76 » Sun Jan 05, 2014 3:36 pm
Sounds like it may be your valve that needs replacing, an easy enough job with the tyre off.
#3
by MartDude » Sun Jan 05, 2014 4:14 pm
Even simpler, and cheap. Remove then replace the valve core - might be a particle of dirt stopping it closing properly.
Shetland Woody
#4
by Shetland Woody » Sun Jan 05, 2014 4:50 pm
Mix up some fairy liquid in a squirty bottle and spray it all over the rim. If you get bubbles anywhere, there's your leak.
#5
by blinkey501 » Sun Jan 05, 2014 5:38 pm
Tonyunn wrote:can I get a tube put into a tubeless tyre.
No go mate
GregD-UK
#6
by GregD-UK » Sun Jan 05, 2014 5:43 pm
Go to halfords and get a couple of schraeder valves. I carry them on my van for expansion vessels in boilers
#7
by D-Rider » Sun Jan 05, 2014 5:50 pm
Tonyunn
#8
by Tonyunn » Mon Jan 06, 2014 7:45 am
When the weather improves it's going back to the fitters.
cheers as ever for the replies.
wayno
#9
by wayno » Mon Jan 06, 2014 8:16 am
Shetland Woody wrote:Mix up some fairy liquid in a squirty bottle and spray it all over the rim. If you get bubbles anywhere, there's your leak.
Best place to start.
#10
by fatboy » Mon Jan 06, 2014 7:21 pm
Im surprised the tyre fitter has not already removed the valve core ect. Sometimes even releasing the core just a few threads can dislodge crap and make it seal.
The soapy water trick should reveal problems, worth a go !
#11
by D-Rider » Mon Jan 06, 2014 8:30 pm
I'm sure this thread is completely baffling to our Norfolk contingent. They really aren't familiar with the concept of soapy water and its various uses.
#12
by Aladinsaneuk » Tue Jan 07, 2014 9:31 am
is it connected to soapy tit wanks?
#13
by D-Rider » Tue Jan 07, 2014 10:20 am
Stop trying to sound as though you have some idea of what soap is
#14
by MartDude » Tue Jan 07, 2014 11:49 am
Aladinsaneuk wrote:is it connected to soapy tit wanks?
Which you can get at Ikea
#15
by fatboy » Wed Jan 08, 2014 7:33 pm
