Time for a new battery.
- stumblebum76
My battery doesn't seem to be holding much of a charge anymore so it's time to replace it methinks, can any of you fine chaps recommend me a decent replacement please? I've been looking at motobatt's are they up to the job? Many thanks in advance.
At the risk of being cited for returning to type, I suggest you use the search function as so much has been discussed on batteries and the best ones probably identified.
.... but in summary the best combination of capacity and CCA is the YTX14H-BS (the H is important)
Go for a good, reputable brand such as Yuasa - these bikes don't appreciate you skimping on batteries - a big false-economy
For example: http://www.batteryshoponline.co.uk/yuas ... s-94-p.asp
That's the first I found - you may find cheaper elsewhere.
- stumblebum76
Many thanks for your reply, I did a search for Falco battery in the search box but it just came up with different subject threads. I don't mind splashing out on a battery so price is not a problem, saying that, the site you have linked to is the cheapest after doing a search so thankyou!
- Willopotomas
- stumblebum76
- randomsquid
- Wear the Fox Hat
I've got one on the ER6 and it's been golden. Being a twin it takes a fair whack to start and the factory yuasa battery was always a bit marginal, especially in the cold. The next one on the Falco will be a Motobatt.stumblebum76 wrote:Do you use one? Are they the same size as the original?Willopotomas wrote:Motobatt are also very good and worth a look IMO.
The kwak one was smaller than the original in height but came with a clip on spacer, also has sensible terminal locations. The only problem with them is being a gel type you don't get much warning before they go south. The dynavolt one I had on before was peachy in the morning and knackered the next time I came to start the bike.
I put a Motobatt equivalent on my Ducati 888 recently and it's a monster, both in dimensions and in torque. I had to shave bits off the plastic to get it to fit in the battery tray, but it spins the old girl up faster than she's ever been spun before.
There was a distinct whiff of 'young man, what do you think you're doing?' when I started her up late last year. It really did get the internals whizzing around.
Having said that, it'll be a YTX14H-BS for me when I need a replacement for the Falco. The specs are noticeably better than the Motobatt equivalent, but what irks me about the Motobatt is that there's about 17% of space wasted, as it's undersize and they supply a 15mm spacer to pad the battery size out. If they'd made the casing full size and given us 17% more grunt, I'd probably go for that.
I got one of these and it has been fine for 14 months now, never let me down.
http://www.amazon.co.uk/MotoBatt-QuadFl ... ilia+Falco
And there price is not to bad.
Speed Blue SL 1000 Falco
That's intriguing - The seller is claiming it to be a 14 Ah battery - just thought I'd check the spec on Motobatt's website - which confirms it to be a 14 Ah battery:
http://www.motobattbatteries.com/motobatt-mbtx12u.html
BUT
Also Motobatt show it as a replacement for 5 Yuasa batteries - and gives (motobatt's version) of the spec of the Yuassa batteries ..... which is significantly worse than the spec that Yuasa gives (I guess it's not surprising that Motobatt would want to make their battery appear superior .... but there seems to be some funny business going on somewhere.
Here is the Yuasa spec book:
http://www.yuasaeurope.com/images/uploa ... alogue.pdf
BUT
- stumblebum76
- stumblebum76
Did you have to space the battery out at all or is it the same size as the original?Tonyunn wrote:I got one of these and it has been fine for 14 months now, never let me down.
It fitted fine, the terminal posts can be altered to suit. I have had no problems with mine and they are recommended for bikes because of their internal construction.
To be honest I think any "good" battery kept up to charge will be OK, it depends on how you feel.
- stumblebum76
Tnankyou for the info, is it right that you don't need to charge the battery first you can just fit it straight to the bike?Tonyunn wrote:It fitted fine, the terminal posts can be altered to suit. I have had no problems with mine and they are recommended for bikes because of their internal construction.
- stumblebum76
I thought I'd still ask as it says in the blurb here http://www.amazon.co.uk/MotoBatt-QuadFl ... ilia+Falco that it comes ready charged.D-Rider wrote:From memory, most tell you to fully charge them first.
