Having more trouble starting
- stumblebum76
I haven't ridden the bike for nearly two weeks and now it just won't start. I put the fast idle on full and it just phuts away not firing, I've tried everything short of using the full throttle trick as the last time I did it the bike really didn't like it banging and popping all over the place and smoke coming up from under the exhaust/engine area! Is there anything else I can try as I'm desperate to get the bike running. Many thanks in advance for any help you can give.
- stumblebum76
Been there, done that, getting bike to fire with random throttle openings.
Managed to make neighbours think they had woken up in a Syrian suburb with the noise.
Cured by sorting idle stop adjustment, took 45 mins, worth the time for the result, get brave, lift the tank and know she will start
