Front paddock stand
- stumblebum76
Front paddock stand
Hi all, can anybody please recommend a good front paddock stand for the Falco? I've done a ebay search for falco front paddock stand which throws up a few but I don't honestly know if they are any good! Any help muchly appreciated.
- DavShill
Hi mate - I use one like this. Takes a little care the first couple of times you use it before having confidence. It's not the most secure but it does the job for routine wheel and brake maintenance.
http://www.ebay.co.uk/itm/Warrior-Front ... 0652457070
- stumblebum76
Get one of the old NWS stands, they come up on ebay from time to time for about £50, same as the abba stand but universal and you don't need to pay for extra pins. Solid as a rock, you can then strap down the front or rear depending on which way you're working
Here's a pic of one http://www.bikechatforums.com/viewtopic.php?t=260045
I've got one of them - certainly more robust than the abba but doesn't have some of the useful abba accessories - though I'd not swap it for an abbawayno wrote:Get one of the old NWS stands, they come up on ebay from time to time for about £50, same as the abba stand but universal and you don't need to pay for extra pins. Solid as a rock, you can then strap down the front or rear depending on which way you're working
