No longer Wanted: gear shift lever
Due to a stupid mistake on my part, my previously undamaged Falco is in need of an un-bent gear lever (the bit you move with your foot).
If anyone has one 'surplus to requirements', I'd like to talk to you.
Thanks,
Thanks,
- Falconihlist
Cheers,
V
I have a 'Wanted' notice over on 'the other place' and have had a reply already. Leigh has just got back from his annual NZ trip and I don't think he'll be doing much, as one of his mates was killed whilst over there.FalcoPops wrote:Hey Steve, try Leigh on AF1 he's usually got a few parts kicking about
I ran a GP-style setup on my old Honda years ago. I'm a bit reluctant to do the same to the Falco at the moment, though. I'll keep it in mind for the moment, though.Falconihlist wrote:If you don't mind going gp shift, I am removing mine off my Bluono for a set of AP rearsets in the next week.
Cheers,
V
Quick update:
Leigh doesn't have any Falco bits lying around. I found a lever on eBay but the postage cost from America is the same as the cost of the lever.
Falconihlist, you have a PM.
Cheers,
V
Cheers,
V
It's a very tempting idea, but I think Mrs Viking would have a screaming pink fit if another bike appeared in the garage. Not to mention the huge number appearing on the credit card statement.D-Rider wrote:I believe K1w1boy has one for sale ..... but it's rather expensive and comes with all the remaining parts of a Falco attached.
Probably not quite what you were looking for .........
I had thought about it, but wasn't too keen on the idea. I've tried to straighten bent alloy things in the past and ended up breaking them.Falcopops wrote:Have you tried straightening your old one?
I suppose a gentle application of heat (via a blow-torch) would help?
Hurrah!I wrote:I had thought about it, but wasn't too keen on the idea. I've tried to straighten bent alloy things in the past and ended up breaking them.
I managed to get it about 95% straight last night. A "gentle" application of blow-torch and a dirty-great-big hammer sorted it. Yay!
I also cleaned a ton of crap out of the linkages on there and regreased the gear lever. So much smoother now.
And on top of that, I have a new gear lever coming from a very helpful Aprilia owner in Sydney.
