Garage heating
Garage heating
How do people heat there garages?
I was thinking of tubular heating or some kind of wall mounted heater.
Just to provide background heat to keep off the chill.
calor gas heater
free from freegle....
a week later some one offered a cal or gas cylinder for free (actually the offered 4 - i grabbed them all and traded 3 for other stuff...)
If you get a log burner then you could potentially get a good amount of free fuel, I'd be tempted to duct some air around the outside of any single insulated flues you had and bring that air back into the garage (to get maximum efficiency out of it).
Don't forget that inside the garage and anywhere it passes through the structure needs to be the double insulated stuff (which is about £50 a metre) to stop if burning you and anything else it's near.
No to calor gas heaters - the fuel gives off water vapour when it burns; you'll have condensation.
I've used the tubular heaters for keeping the chill off sheds & greenhouses. 2 x 60 watt heaters were enough to keep the frost off a 9' x 5' greenhouse, with minimal insulation.
As Martdude says,portable gas heaters give off a lot of condensation, can also cause respitory problems.
TBH a no naked flame heating system makes more sense, but an excellent wood burner can be made from a Calor gas cylinder, tons of radiant heat
my main heating source
- BikerGran
- Gran Turismo
As made by Chris Ireland of trike fame!fatboy wrote: an excellent wood burner can be made from a Calor gas cylinder, tons of radiant heat
http://www.mankymonkeymotors.co.uk/Tech ... eater.html
- Willopotomas
Small storage heater (which I've got to wire up..lol). For the time being, I'm using an oil filled radiator on a timer. The garage is quite large and insulated and it doesn't take long to warm up. I leave it on the timer to keep condensation off over night. It's probably on for a total of 6 hours in 24. Even though it's insulated, it doesn't mean it can't get kin' cold in there without the heater. Similar to a house that's been left unoccupied over a winter. Damp.
Under no circumstances use a Calor gas heater in the garage. Not only do they produce water vapour, but also having flames in a garage is not generally a good idea. lol
http://www.ebay.co.uk/itm/DELONGHI-DRAG ... 4aca85d853
