Garage with No Power
mrapriliafalco
#1 Post by mrapriliafalco » Fri Sep 20, 2013 10:50 am
Does anyone else have this Problem! I was wondering how you keep your battery charged,I have a optimate.Has anyone got novel ideas
Re: Garage with No Power
#2 Post by D-Rider » Fri Sep 20, 2013 11:16 am
mrapriliafalco wrote:I was wondering how you keep your battery charged,I have a optimate.Has anyone got novel ideas
I tend to ride my bike - it has built in charging facilities that tend to keep the battery charged.
(when I go away I do use an optimate as I do have power in my garage but if I didn't and I was gong away for a long time, I'd do what the owners manual suggests and disconnect the battery.
If I was going away for a very, very long time, I'd pull the battery out and charge it indoors)
mrapriliafalco
#3 Post by mrapriliafalco » Fri Sep 20, 2013 1:28 pm
hahaha never thought of riding the thing :smt005
if you remove the batt does the alarm no bleep every 10 secs
#4 Post by D-Rider » Fri Sep 20, 2013 2:16 pm
Well alarms are not standard so probably different alarms do different things.
It's a good point though - pulling power from the alarm and running down its own battery is something that I'd not really considered.
#5 Post by DavShill » Fri Sep 20, 2013 2:22 pm
My lad had the same dilemma and he rigged up a little solar pack (from Maplins I think). Seemed to do the trick well enough to keep the battery topped up. If your search the usual places I think you'll find something.
#6 Post by fatboy » Fri Sep 20, 2013 5:38 pm
I use a solar trickle charger, does the job, £10 from Maplins.
Got a bit pissed off with removing seat to connnect/disconnect croc clips every day so used ring connectors,but charger leads are ultra thin and too easy to break being kak handed when separating the battery leads from charger.
In my case its solar charge or no charge so I stopped being kak handed !
Cathcart
#7 Post by Cathcart » Mon Sep 23, 2013 10:02 pm
I'm in the same boat mate. I just use the bike often so it doesn't ever go near flat. I've always meant to fit a kill switch for the battery.... even have the switch and wire.... just never done it....
Marco Simoncelli.
