browny
#1
by browny » Sat Aug 31, 2013 6:20 pm
Hi, can anyone advise whether or not the light above the number plate is a legal requirement. I only ask as mine has stopped working and since i now have a tail tidy fitted i was about to buy a new smaller number plate and remove the light completely so that I can get the plate higher on the tidy.
Just remembered my bike is a Falco, tidy purchased from Wayno
[/quote][/url]
#2
by blinkey501 » Sat Aug 31, 2013 6:47 pm
browny wrote:Hi, can anyone advise whether or not the light above the number plate is a legal requirement. I only ask as mine has stopped working and since i now have a tail tidy fitted i was about to buy a new smaller number plate and remove the light completely so that I can get the plate higher on the tidy.
[/url][/quote]
A light is a legal requirement. A smaller number plate is a £60 on the spot fine.
#3
by D-Rider » Sat Aug 31, 2013 7:24 pm
I'm not sure of this but Pete maintains that a light is not a legal requirement but if one is fitted it must work.
Safest thing is to make sure you have one and that it works.
#4
by Aladinsaneuk » Sat Aug 31, 2013 8:07 pm
Not a legal requirement (mot wise)
But
If fitted must work
A reflector is a legal requirement for mot
I did not have a problem when I had no plate light
#5
by fatboy » Sun Sep 01, 2013 5:04 pm
You would be in trouble riding in the dark without your regitration illumimated.There are some very discreet LED's out there for £15/20 ish, even some with in built indicators.
By discreet I mean around the size of a 20p coin
Small numberplate means INSTANT PULL !
Choose wisely
#6
by Aladinsaneuk » Sun Sep 01, 2013 5:24 pm
I decided to look further and found another uk law anomaly....
You do not need one for an mot but you cannot fail an mot without one but would get an advisory
http://www.legislation.gov.uk/uksi/2001 ... 561_en.pdf says you DO need one between sunset and sunrise....
browny
#7
by browny » Sun Sep 01, 2013 5:53 pm
Cheers for the advice fellas. .. plate size I am considering it's 7x5 andI may have to consider getting an after market light ... think I have seen them on e Bay
#8
by D-Rider » Sun Sep 01, 2013 6:26 pm
Aladinsaneuk wrote:I decided to look further and found another uk law anomaly....
As I've said on more than one occasion, requirements for MOT do not necessarily confirm the legal requirements for the condition or use of the vehicle.
Construction and use regs etc need to be considered too
- Wear the Fox Hat
#9
by randomsquid » Mon Sep 02, 2013 5:30 pm
browny wrote:Cheers for the advice fellas. .. plate size I am considering it's 7x5 andI may have to consider getting an after market light ... think I have seen them on e Bay
Stick led number plate bolts on it and stick the reflector where the number plate light used to be.
#10
by fatboy » Mon Sep 02, 2013 5:44 pm
Standard size is 9x6 so 7x5 may be pushing your luck, 8x5 is only half an inch off each long side without looking like its taking the piss big time
wayno
#11
by wayno » Tue Sep 03, 2013 9:43 am
Mine's a 8 x 3 :)
Browny, get a couple of birght white LEDs and screw them through the underside of the plastic (from the inside of the rear seat compartment). This will give you as much light as a small LED number plate light and be completely invisible to the naked eye (apart from the magic glow of course). Then you can stuff the number plate right up to the top.
You will just need to worry about waterproofing them.
browny
#12
by browny » Mon Sep 09, 2013 9:12 pm
wayno
#13
by wayno » Tue Sep 10, 2013 6:25 am
motoshowplates.com sent me a discount code the other day
IndianSummer2013
It expires on the 12th September though so get in quick
browny
#14
by browny » Tue Sep 10, 2013 6:11 pm
Cheers for the info Wayno
