Wanted: Standard license plate light
- Firestarter
- Twisted Firestarter
Anyone got a standard license plate light to fit a Falco to sell? Bolts sheared when taking it off to fit the new tail tidy
Thanks in advance
Thanks in advance
I think pete means this
http://www.ebay.co.uk/itm/NEW-LOOK-X1-A ... 2c7177be8e
- Firestarter
Nope, one probably could get a couple of threads picked up, but the other is too short to stick through the tidy. Typically, they're moulded into the plastic, too much faff to dig them out and replace them
Had a look at the bolt lights, not overly keen on them. Although it's plasticky, the stock one is fairly unobstrusive, saw some Motrax efforts but £15 is a bit much for some plastic and leds.
Andy, let me know what you want for the one you've (maybe) got, no rush, quite happy to run without for a while, but will fit one - one less thing for some picky copper to use as an "excuse" to pull you over
- randomsquid
- Wear the Fox Hat
- randomsquid
- Wear the Fox Hat
- Firestarter
- randomsquid
- Wear the Fox Hat
- randomsquid
- Wear the Fox Hat
- Firestarter
Not surprised!randomsquid wrote:Posted it yesterday evening should be with you tomorrow with a bit of luck.
Got a dirty look from the postwoman when I walked up to the counter and whipped my packet out of my leathers.
Cheers matey, will let you know when it's arrived, and hopefully pop some pics up of the finished article
