clutch jet
clutch jet
Hi I want to change my clutch jet to get a smoother gear change ive been reading that i will need an 0.4 jet but ive no idea how to actually change it does anybody have a link or an guide on how to do this (with pictures) thanks
Darrell Turner
Your lucky I have been working on one of the bikes today.
Buy a jet direct from Griff "Aprilia performance" 01827285500 and he sell you one delivered for about £13.
Then remove sprocket cover.
The clutch jet is fitted behind an allen screw which you have to remove.
The jet is located in here.
MAKE SURE YOU BUY A SCREW DRIVER THAT FITS ABSOLUTLEY SPOT ON IN THE SLOTS OF THE NEW JET BEFORE REMOVING THE OLD ONE.
Undo the jet inside the engine and grip the jet with a cocktail stick by pushing the stick inside the hole.
There are a lot of posts about this in the Falco part of the forum - use the search function to help find them
Also (handy hint) when posting in the general Ridersite forums, it's a good idea to mention what make and model of bike you are talking about
Anyway, hope you get it fitted and notice a good difference.
