Fitted EBC heavy duty friction plates today, coated them in oil on wed, when they arrived so should be good to go.
Went to torque springs to 11 nm using an inch/pounds wrench, the conversion being something like 108 inch/pounds, I didnt achieve the torque setting, it felt way too much.
Test ride,major clutch slip so I released the tension, tightened up evenly by hand to 'pinch' tight ( this stratergy worked when I re assembled clutch after inspection)
Now I have slight drag,thunk engaging 1st, cant select nuetral but slips like hell over 2000rpm.
Did notice after fitting plates, they were slightly ' prouder ' than originals.
Im thinking heavy springs needed also ?
Any ideas welcome !
New friction plates, mega clutch slip ?
although the final plain plate engaged with the hub, that was with a cold motor, maybe the expansion is enough to 'throw it out '
will look again tomorrow, sods law says my laptop wont let me access my download manual, my ebay paper manual has not arrived !
Fuck it, beer oclock !
