Cathcarts Falco
Cathcarts Falco
2003 black/bronze
Bellypan
Clutch jet
15/42 gearing
Gear indicator (cause I always forget what gear I'm in)
Shorty levers
Led front indicators
K&N air filter
Forza chip
Art end cans
HEL braided front lines
Ebc HH pads
Factory pro clutch slave
Rsv sprocket cover
Rsv steering damper
Iridium plugs
Gsxr sidestand
Reg/rec wire mod
150amp starter relay
Black db screen
More to come....
Bellypan
Clutch jet
15/42 gearing
Shorty levers
K&N air filter
Forza chip
Art end cans
Ebc HH pads
Rsv sprocket cover
Rsv steering damper
Iridium plugs
Gsxr sidestand
Reg/rec wire mod
Black db screen
More to come....
Marco Simoncelli.
Marco Simoncelli.
- Falco Frank
A wee update....
Over the coming winter the bike shall be street fightered. Open to all advice or suggestions.... Excluding anything along the lines of "don't do it".
I have to use the Falco, loads of character and a cracking engine. Great bike and not worth what they should be. I plan on doing it all without damaging any original parts. That way I can resort it back to standard whenever I want.... Although I may be drilling the top yoke.... Undecided... Even the colour is undecided...
Gary
Gary
Marco Simoncelli.
Marco Simoncelli.
.... well I was thinking of adding a "Please" .....Cathcart wrote:A wee update....
Ah OK - I'll let you off then.Cathcart wrote:I plan on doing it all without damaging any original parts. That way I can resort it back to standard whenever I want.... Although I may be drilling the top yoke.... Undecided... Even the colour is undecided...
Gary
The parts for these are far too rare to be destroying or cutting up, it'd be a shame to. Only thing I can think of that may be damaged is the top yoke... Granted, it'll all be painted though... So as far as original colours go... They'll be changed.
Good news though, I have a yellow spring rsv shock here and a linkage is en route. I'll finally see what you all keep talking about....
The Falco parts will not be sold, these will be kept incase I change it back.
Marco Simoncelli.
Marco Simoncelli.
- randomsquid
- Wear the Fox Hat
A fairing will have to be "Modified" to fit if it is fightered!!!!!!D-Rider wrote:.... well I was thinking of adding a "Please" .....Cathcart wrote:A wee update....
Gary
And may i suggest http://www.motomac.it/Aprilia%202/Futura_RS.htm
D rider is spot on, the fairing won't be getting used, although it will be paintedat the same time. This way, if iI rebuild then they'll match.
Seen that site before but nothing really jumps out as being quite "me".
Bike will probably have dominator headlights and street fighter bars.
Marco Simoncelli.
Marco Simoncelli.
- randomsquid
- Wear the Fox Hat
