The changes I’ve made to the factory-delivered spec have been done to make the bike easier to ride – so more enjoyable to ride and safer too. Basically the main areas of change have been uprated handling, braking and throttle response. It’s not entirely “bling-free” but that’s a secondary thing.
I’ve probably missed something or other but this should give you an idea.
- RSVR style (04 onwards) carbon front mudguard
BST Carbon Wheels (Diablo Rosso Corsa tyres) / OZ forged wheels (Angel ST tyres) - BSTs currently fitted
Ohlins Forks
RSVR-Factory Yokes (powder coated in gold) (set on 4-rings)
MilleR Ohlins shock and linkages (set at max ride height)
Mille 4-pad callipers
Brembo racing radial brake master cylinder
Hel braided brake lines
RSVR radial clutch master
MWR clutch slave
Hel braided clutch line
R&G bar ends
R&G crash bungs
HID dip-beam with wiring mod to keep on when main-beam is on
Double-bubble screen
Home-made mount for Garmin Nuvi navigation with built-in charging
Mike’s Grilles Radiator and Oil Cooler covers
15t front sprocket
Tuono sprocket cover
Seat quick release pins
Optimate charger point
Smoked tail light lens
Nooj’s LED tail light boards
Meta alarm
Mille Swinging Arm with CF covers
Renegade Air Kit
Mille exhaust mid-section modified to fit Falco headers and both balance-pipe mods added (2into1 system)
Fuel Hi-mount oval can in Carbon effect stainless
Modified RHS pillion peg mount to clear Hi-Mount Exhaust
Gabro chip with maps for both 51mm and 54mm TBs and my bike’s config.
PCIII USB (currently disconnected since fitting Gabro chip – may get Advance Map done “on top” of Gabro chip …. though Gabro is so good it’s not an urgent priority)
54mm TBs (currently being swapped in and out while I try to get them optimised for my bike - today they are out)
Skidmarx bellypan
GSXR sidestand
Scottoiler with double injector.
DENSO Iridium Plugs
Mactat double-lion-head tank protector ….. an original one!
Clutch jet mod
Longer oil filter (actually have both housings do either can be fitted)
- Aprilia Falco pannier frames & panniers
GIVI rack (Falco specific)
Modified rear seat pad with mount for small GIVI top box (plus top box)
Aprilia Tank Bag
- MWR CF Hugger for Falco Swinging Arm
Tuono coolant header tank with CF cover
Mille oil tank
MilleR stainless oil tank
Mille oil cooler
Mille exhaust system (headers and mid section)
Renegade plus02 chip (never fitted and probably never will be)
- Schlosser style side-panel and Mille bellypan mod (started ages ago)
Head-up display (wiring partially fitted ages ago)
Here are some pics (though none are quite as it is now):
