Does anyone know if the Standard Falco Front wheel spindle
fits Mille-R Ohlins front forks please. I ask because have seen on the
web that one was mentioned as ONLY fitting the Ohlins forks and NOT
the standard Sachs ones.
Secondly, is there any real difference in braking power or benefits between
the early 1 pad per PAIR of pistons Brembo's or the later model of 2 pads per pair (1 pad per piston).
Thanks.
