zoidberg
#1
by zoidberg » Sun Jul 07, 2013 6:29 pm
First proper run out on the falco today.
Still need to sort a few things......but what a bike.
A 15t sprocket is next on the list along with a rear shock.
It does everything though. It will happily bimble about quite civilised but open the tap and it becomes a hooligan.
If carlsberg built bikes. ....it'd be the Falco
#2
by Aladinsaneuk » Sun Jul 07, 2013 6:35 pm
Yes
Prepare your cheque book
#3
by D-Rider » Sun Jul 07, 2013 6:46 pm
Now just mind you don't let the cat out of the bag - this is biking's best-kept secret
#4
by joecrx » Sun Jul 07, 2013 7:24 pm
great bike
i wasint going to mod mine and keep it standard, cause standard is rare to, but over the years iv been doing little bits here and there , now ready for the millie swinger mod , then shocks then cans , i have a list and getting through it when i have pocket money and time to spare
#5
by joecrx » Sun Jul 07, 2013 7:26 pm
zoidberg wrote:First proper run out on the falco today.
i thought 15 tooth was standard, dont know what mine is but going to fit a 16 with 42 rear ,
#6
by D-Rider » Sun Jul 07, 2013 7:29 pm
16 / 41 is standard.
many of us prefer 15 /41
16 / 43 is very close to 15 / 41 but requires a longer chain.
16 / 42 is half way between stock and the "usual" change
zoidberg
#7
by zoidberg » Sun Jul 07, 2013 8:25 pm
Gearing is way too tall for my liking. Slipping the clutch in third or revving it in 2nd is a little annoying.
#8
by HisNibbs » Sun Jul 07, 2013 8:45 pm
zoidberg wrote:Gearing is way too tall for my liking. Slipping the clutch in third or revving it in 2nd is a little annoying.
What on earth are you doing? If the gearing is too tall I can understand slipping the clutch in first, but third?
#9
by D-Rider » Sun Jul 07, 2013 10:02 pm
What he said!
zoidberg
#10
by zoidberg » Sun Jul 07, 2013 11:04 pm
Chatters and feels awful pootling around at low speed.
Slipping the clutch helps.
#11
by D-Rider » Sun Jul 07, 2013 11:37 pm
Hmmm how low?
I can run mine in 6th at about 35mph as long as I don't wind the throttle on too quickly (with 15/41 gearing).
Might be that your throttle bodies need balancing,
zoidberg
#12
by zoidberg » Mon Jul 08, 2013 7:00 am
15-20, most likely need balancing though I'll get them done.
PH1969
#13
by PH1969 » Mon Jul 08, 2013 11:12 am
Told you
2013 KTM 990 SMT
2001 Aprilia Falco
2002 Buell X1 Lightning
1967 T120R
Falco Frank
#14
by Falco Frank » Mon Jul 08, 2013 12:26 pm
44T on the back of mine has altered the feel o the bike totally, i keep going for a seventh gear, acceleration is now more than 'brisk' and so willin to respond to any throttle demand as well.
Wish i done it ages ago. Might need a longer chain for this mod?
#15
by fatboy » Mon Jul 08, 2013 6:46 pm
zoidberg wrote:Chatters and feels awful pootling around at low speed.
In the meantime, leave the fast idle cable slightly 'engaged' so your tickover speed is around 1500 to 1750 rpm, this will help with the lumpy hesitation.
It is a V twin charecterisic to be 'all or nothing' on low throttle openings.
If you need to slip the cluch in 2 an 3, you need some tuning.
I only slip the clutch to keep the front on the tarmac, yes sometimes from 2nd to 3rd
A falc does have the poke to do that !
