where can i get a rear break master , mine has all stuck up cause its been sitting for so long , and wont pump to bleed the break, as if the piston has went in and wont spring back .
i did take a vid but dont know how to post it, the lever just goes all the way down and back up with no preasure
the ducati 896 is a direct replacement £ 50 notes , i fitted it today , solid as a rock , bleed the calliper upside down , i also fitted a bleed nipple on th master but did not need to use it
part numbe r625400061a st
there is other numbers on the box but im sure this is the part number
