q/r seat pins
scottyni
q/r seat pins
#1 Post by scottyni » Fri Jun 28, 2013 1:54 am
Where can we buy the quick release seat pins?
if you can't ride it....
OR take it too bed...
IT AIN'T WORTH HAVIN...
Re: q/r seat pins
#2 Post by blinkey501 » Fri Jun 28, 2013 5:13 am
scottyni wrote:Where can we buy the quick release seat pins?
https://www.ridersite.com/viewtopic.ph ... ck+release
Re: q/r seat pins
#3 Post by Falcopops » Fri Jun 28, 2013 7:05 am
C'mon mate, a man of your talents should be able to knock up a set of these in no time.
I used a couple of coach bolts, cut off the heads, screwed them through the holes and fitted them with nyloc nuts, marked the height for the pins and drilled holes, fitter some R pins, done.
scottyni
#4 Post by scottyni » Fri Jun 28, 2013 8:06 pm
Dale, you have shamed me :smt002 Just lazy
Will make a set when time
