Took the bike out of the garage to give it a clean and whilst I was cleaning the wheels thought I'd start her up and warm her through. Did this for about 5/10 mins but took the choke off a bit early and she cut out ,so left her turned off and carried on cleaning.
Just happened to check the oil level and nothing there!
Absolutely not a scrote showing in the sight tube. Now the last time I remember checking it was at the marches meet when it was about halfway between max and min when cold. I know you should warm it up before checking the level. Have only ridden home from newcastle on clun and out to a bike night since so probably done 200 miles since I last checked it.
I stripped the belly pan off and no sign of any oil there, none around the drain plugs, just a little noticed around the top left of the front cylinder and a little had dripped onto the starter (left hand side)
I daren't start her up any more until I'd topped the oil up, so got a litre today . topped her up with approx 700ml until the sight tube was showing halfway again.
Started her up and watched as the oil level in the tube disappeared off the top of the scale
drained some off and warmed her fully up ,then drained more until the level was halfway between the marks again and guess how much was in the measuring jug . Yep about 700ml
where was this oil hiding and can I expect this again in the future, was quite worried for a while.
Also any idea where the small amount of oil could be from, I've cleaned it off now so will check after my next ride.
