SL Cans and chip
SL Cans and chip
Hi all, back here after a short break
. Can anyone advise if I MUST have an SL eprom to use with the SL cans? Or is the original chip ok to run just the cans on, many thanks.
Old age pensioners, hah, should be shot at birth!!!.
05 Bronze 'n Black. Nice!
- flatlander
If you cant get a Gabro have a word with Ed ( Forza Aprilia) and he will map one to your demands ...
why is it better? ... It just is miss
Basically and IIRC each chip has different key characteristics and effectively manages a certain set of conditions. There is a natural tolerance within these parameters which allows them to manage conditions that they were not specifically designed/mapped for.
Basically if an open set of cans needs a certain mapping then chances are others with similar characteristics will not make dissimilar demands so you can get away with some mix and match.
That said like most tech stuff it will almost always work more efficiently within the exact conditions for which it was designed.....
obviously with the exception of almost anything designed for a Microsoft setup
The other thing to bear in mind with chips such as those Gabro puts together is that not only are they more suited to the modifications you might have made to your bike (you tell him your setup, he'll provide something to suit), he is not encumbered by having to meet noise and emissions regulations which compromise the fuelling of the OEM chips. You may well find that not only do they give a smoother delivery and more power but may well save fuel too. A common way of quietening bikes down is to chuck in excess fuel at the engine revs at which the noise tests are conducted.
It's a black rectangular plastic thingy with a row of metal legs down either side.
I don't have one but I have heard that it's fairly good with aftermarket and SL cans but tends to over-fuel.
I have heard it is not as refined as a Gabro (for example)
That said, it's certainly a reasonably highly rated chip.
Depends where they are broken and how good you are with a soldering iron - you need to be good enough to make a good joint whilst being quick enough not to fry the chip.Aladinsaneuk wrote:look at the pins and the board (Or top of the chip)
there is a mark to show the way round it goes in
BUT
if it has broken pins..... i wouldn't bother
..... that said, I'd find it the perfect excuse to justify a Gabro
theres no mark on the 'daughter board' to say which way round it goes. i know the chip itself is notch to notch.Aladinsaneuk wrote:look at the pins and the board (Or top of the chip)
BUT
the pins on the 'daughter baord' are very fragile and have broken off, i know an instrument tech who is gping to have a go at repairing them.
who sells gabro chips? i was going to get a forza chip if it can't be repiared.
Passes can of worms...
My personal view
Do the mods you want - and get a gabro chip made for that setup
Ed - forza's chips are also according to many good but are more generic
Also consider balancing etc
Power commanders have a place but with the gabro chip not totally necessary.... Only really for those wierdo's with strange hybrids....
My personal view
