www.wf-designs.co.uk promoting my CAD Design business
wayno
#1 Post by wayno » Thu Jun 06, 2013 11:02 am
As per the title this is a blatent promotion of my own company. I do 2D & 3D engineering CAD design, this service is available to everyone, not just businesses.
Have a butchers
#2 Post by Willopotomas » Thu Jun 06, 2013 5:02 pm
Nice :smt004
#3 Post by fatboy » Thu Jun 06, 2013 5:54 pm
Nowt wrong with promoting a bloody usefull service
#4 Post by D-Rider » Thu Jun 06, 2013 10:51 pm
fatboy wrote:Nowt wrong with promoting a bloody usefull service
What he said.
:smt004
#5 Post by Viking » Thu Jun 06, 2013 11:53 pm
Nice work. I hope it all goes well for you.
wayno
#6 Post by wayno » Fri Jun 07, 2013 1:48 pm
I've been doing the job on a contract basis for about 4 years (permanent before that), I set up my own company 2 years ago and have just decided that on top of the main contract I do on a daily basis that I'd start taking on some extra work too.
I figure with 3D printers becoming so popular now that more people will need someone to create 3D models of what's in their mind, people will always be looking at getting CNC parts made, which is easier if you already have a 3D model done rather than giving a company a fag packet sketch.
If you know of anyone who might be interested in my services feel free to pass my details onto them, regardless of whether they are a professional company or Dave down the road who needs a drawing doing of his broken whatyamacallit to get a new one made.
#7 Post by fatboy » Fri Jun 07, 2013 6:37 pm
Handy stuff you can do there !
My mate took a seriously knackered flywheel from a narrowboat engine,someone failed to torque the bolts where the torque converter fitted to the flywheel, nashed threads all round.
With the aid of CAD, they re drilled and tapped 5 new mounting holes, equidistant to the originals, no compromise in strength, all done in half an hour !
#8 Post by HisNibbs » Fri Jun 07, 2013 8:57 pm
Hi Wayno, this used to be my area of expertise. In the late 80's early 90s I was Chairman of the Autodesk developer's group and created parametric design and drawing management extensions to AutoCad. Before that I did a lot of 3D surface modeling and CNC machining work. Also worked for Aveva on PDMS. Anyway if you want a second opinion on a thorny application or programming problem it might be worth running it by me. Good luck with your business.
#9 Post by Willopotomas » Sat Jun 08, 2013 12:41 am
Keith. Not wanting to create tension, but why is AutoCAD so rubbish when it comes to drawing even the simplest of things? My only experience of AutoCAD has been dreadful every time.
At work we use specialist CAD/CAM systems for the waterhet (quite basic), and Solid Edge for 3D applications.
#10 Post by HisNibbs » Sat Jun 08, 2013 12:33 pm
Hi Will,
AutoCAD's strength was its customisability and programmability. I could make it do just about anything the expensive "better" systems could at a fraction of the cost and then automate it, so the work could be done in a fraction of the time.
Times have changed and there are a lot of low cost CAD options around.
wayno
#11 Post by wayno » Sat Jun 08, 2013 12:39 pm
Hi nibbs, I may just take you up on that offer :)
