One for nursie? Ear plugs
- Firestarter
- Twisted Firestarter
Ok, don't judge!
I have a habit of re-using ear plugs (mainly cos I usually only have the one pair at any one time), the soft-foam disposable type. Generally wear them for a week(ish) then chuck them when they stop re-expanding properly, or I've dropped them in a pile of something on the floor.
So, how often should I be chucking them before risking an ear infection?
I do the same, use for about a week or until they look skanky or stop shaping easily. I've been doing that for a few years now without issue.
One thing I have done in the past is wash them under some cold water to remove any earwax, came up looking good and didn't adversely affect them in any way.
I commute to work every day so going through a pair a day seems exessive.
You always have a choice
if you were sharing them, then there could be a possible cross infection risk - but unlikely
personally, wear till they look skanky or do not return to shape properly
i would not wash them
oh - one thing - WEAR THEM
applies to any one who travels at over 30mp with a helmet on - after five minutes you have hearing damage
Before you do, have a look at these. Good value, & high performance, for a disposable plug. Originally brought to my attention on here by ? GrgD? Mangocrazy? - can't remember nowCathcart wrote:I'm going to order some today.... Seeing as we're on the subject and whilst I remember.
http://www.lawson-his.co.uk/aearo-earso ... pai-p31163
have to admit i very rarely wear ear plugs i know i should do but i just dont seam to i suppose i am just being lazy which is silly as i dont ride the bike unless i have all my gear on jacket, trousers, boots, gloves and helmet and ear plugs are just as important when you consider that the clothing is there to protect when you come off and the ear plugs are protecting you all the time when riding.
if you unscrew your belly button will your bum fall off??
Cathcart wrote:I'd already ordered 50 pairs of generic orange ones before I seen your post. Nr 37... No idea what it means but I assume they reduce noise by 37db on average.
Yes
NRR 37 is a noise reduction rating of -37dB. so assuming your bike and the noise from riding it is at say 130dB then you're now in a slightly better place.. (the higher the NRR number the better..) and 93dB is still a bit on the high side
You want to aim to reduce it to 70-90dB and avoid prolonged exposure to that level
The yellow E.A.R ear plugs are the very base anyone should be going for.. they come in at about 26dB reduction - I can get these by the hundreds if anyone wants some, but ideally you want to go for a moulded ear plug with a much higher NRR figure.
I was a Joint Service Noise Assessor at one stage of my career however it was a wasted course as nobody gives a stuff as they can't see it.
(My hearing was already fucked before then though from service in the 80's as a youngster)
Oh and it cannot be repaired. once youve fucked your hearing... it's fucked. that's it.
Oh and racal who do the Army moulded earplugs do have an option for Ipod fittings..
http://www.esterline.com/communications ... stics.aspx
Expensive mind.. but worth it
- slickliner6
I work in an industry that uses ear plugs everyday. So I get them from work. It is drummed into us by the medics offshore that:-
a) you have to wear them in areas where you "have to raise your voice to heard" (although its just advice.other areas are mandatory ear protection)
b) DON'T use them twice as " cross contamination"(left to right) can cause ear infections.
Having had an ear infection last year, I don't use the plugs more than once anymore, (touch wood) I won't get another ear infection.
