DoH!
Didnt realise I'd posted the following in Aprilia Tech rather than here:
Bearings supplier: (already posted by Shootmyscoot)
Torrington HK1812V. (6 needed for full set)
If any one needs them they can be got from Motion Industries
Address:
Motion Industries,
Unit 2,
Bracken Trade Park,
Dumers Lane,
Bury,
Lancashire,
BL9 9PE
Telephone: 0161 705 1237 (£8 each now inc VAT)....
Posted by me...
"Big Sweaty Bollox...
Ohlins shock upgrade going in (AT LAST) and discovered that not only is there quite a lot of forward / back play in the needle bearings in dogleg but that the tube that fits into the housing on the swingarm was almost seized and on removal the needle bearing fell to pieces...
On closer examination it appears that NO fugin SEALING RINGS were fitted on the shock linkage AT ALL - thanks
So I can see where to get the Torrington rollers from but does anywhere sell the seals and 'gudgeon pins' separately, please?
Cheers - Frank
Oh yes, suggestions of how to fit the rollers without removing the swingarm much appreciated....
Freezing the rollers overnight maybe?"
dust seals:
"Item 11 AP8110068 8 Needed Oil seal - D18x24x3
as found on:
http://www.apriliagenuineparts.co.uk/co ... s-3670.php "
Just in case its of use, Motion industries not only sell the Torrington bearings off the shelf but also sell Nitrile seals in the right size.
Cost me £70 !!!
For a full set of seals and bearings but at least I know they are as good as can be.
Just ordered a connecting pin from Aprilia Performance as one was damaged and thats another £12.
I hope there are no extra tools needed for removal / install :(
Ive ordered a removal tool for the swingarm tube - anythign else needed or anyone know how to get the new bearing in, please?
