Engine Rattle
philgro64
Engine Rattle
#1 Post by philgro64 » Sun Apr 14, 2013 12:47 pm
Ashamed to say went for my first ride of the year yesterday. Still bloody cold. Noticed a rattling noise under load between 2.5 and 5k revs going through the gears from 2-6. Not noticeable in first. Having looked through the previous posts(using the invaluable search function :smt002 )but couldn't see anything similar. There is no evidence of the rattle when revving in neutral. Any ideas? Thanks in anticipation. Phil
#2 Post by joecrx » Sun Apr 14, 2013 1:01 pm
torque up the 14mm head stock bolt ,
loose front pads / clips pads worn
front rotors, normal if they are full floating
slack chain,
the falco dosent like low revs its a v twin , to high a gear for speed you were doing ,
just my thoughts,
philgro64
#3 Post by philgro64 » Wed Apr 17, 2013 7:03 pm
Thanks Joe, Had the bike 3 years so used to the gearing on the Falco. Due a chain and sprockets change but rattle sounds as if its coming from the engine. Will see how it is after a service. Cheers Phil
#4 Post by Aladinsaneuk » Wed Apr 17, 2013 7:25 pm
If its only under load I would check my chain and sprockets....
#5 Post by blinkey501 » Thu Apr 18, 2013 4:10 am
The Rotax does make a slight rattle when the engine is under load at low revs (excellerating). Do you hear anything from the motor on tick over?
falcomunky
#6 Post by falcomunky » Thu Apr 18, 2013 6:21 pm
Maybe just needs fresh oil?
TBH, mine has been a rattly bugger since I got her 7ish years ago. I've put +30k on her since then (no I don't have the cash for 1000 mile trips round Europe) and she hasn't got any worse (touches wood). :smt003
Two is the magic number... ;)
#7 Post by D-Rider » Thu Apr 18, 2013 8:46 pm
Yeah check:
1) Nothings coming loose
2) Chain well adjusted
3) Throttle bodies are well synched (can be a bit lumpy below 3k if their not)
philgro64
#8 Post by philgro64 » Wed Apr 24, 2013 9:30 am
D-Rider wrote:Yeah check:
Think I've found the cause gents. On doing the oil and filter change(relatively straightforward considering some of the nightmares I have read on here) I noticed the bolt securing the sump to the engine seemed a bit loose. On examination it appears the bolt has sheared leaving the thread inside. Only had a short run since fixing it and no sign of 'rattle'. Thanks for replies. Phil
