Sorted!
Sorted!
Having ridden through the tail end of the uks ice age (aka spring 2013) I'm throwing caution to the wind and proclaiming the electrical gremlin DEAD! Only cost me a grand for someone else to get to the bottom of it but even through freezing days after a short ride to work it has been faultless. Props due then to Southern Cross in kilburn, north London. I got what I paid for ... in the end.
- flatlander
so what was it
I only ask as Alad and DR may need help if you are free
... Dunno if this will help, but part 1 was charging: frayed/'home-spun' wiring causing shorts here and there, notably around the stator. Stator replaced. Wiring fettled. Part 2 - the return of the 'buzz-click' starting failure ended up being a blown cooling fan. More dodgy wiring found and fixed. Fan replaced.flatlander wrote:so what was itI only ask as Alad and DR may need help if you are free
