rear sprocket carrier gasket
#1 Post by joecrx » Sat Mar 23, 2013 3:20 pm
i bought this gasket 38 x52 x 7 item 21 in the pic , it dosent fit ,
i measured about 56mm so should be 38 x 56 x 7 , anyone know the correct size
mcbones
#2 Post by mcbones » Sat Mar 23, 2013 6:30 pm
38x55x7
#3 Post by joecrx » Sat Mar 23, 2013 7:10 pm
i checked all gasket sizes on aprilia yorkshire, rsvt, rsvrm faloco etc and were all 38x52x7.
fits some bikes somwhere but none of the above
can i ask where you got this size mcbones :smt002
mcbones
#4 Post by mcbones » Sun Mar 24, 2013 7:14 am
#5 Post by joecrx » Sun Mar 24, 2013 8:03 am
different size from the one on this page number 21
https://www.apriliayorkshire.co.uk/cata ... ikename=SL 1000 Falco 2000-2003&_pagename=Rear wheel
#6 Post by D-Rider » Sun Mar 24, 2013 10:01 am
Aprilia's own parts manual lists it as 38 x52 x 7 - but that might have just been a typo that has been carried over and now corrected in later literature ............ so, TBH it's not very clear.
#7 Post by joecrx » Sun Mar 24, 2013 10:45 am
just checked my front sprocket , its a 17 tooth , will it fit , im getting frustrated now with this ,
acording to kens site its tight ,
this is a 16 tooth
#8 Post by Falcopops » Sun Mar 24, 2013 10:48 pm
The seal on the sprocket carrier is 55mm outside diameter.
I was just getting all this stuff sorted out to put new bearings in one and the guy at SKF gave me the 52mm one I asked for and it didn't fit, quick measure with the callipers and sure enough the Aprilia book has a misprint.
The bearing size further down the list confirms this at 55 OD
gazzo
Main bike: Falco
#9 Post by gazzo » Sun Mar 24, 2013 11:24 pm
Try going to Gear commander
http://www.gearingcommander.com/
I don't think you would want a 17T at the front.
It'll be like a bone shaker and acceleration will be v poor
#10 Post by fatboy » Tue Mar 26, 2013 7:23 pm
Look at Wemoto for sprockets, big choice of plus or minus sizes on both front and rear sprockets
