Worn gear change links
- KitchenSync
Those little ball and socket things are pretty knackered on my Falco's gear change. I can't imagine that they are a special part though... does anybody know where I could get them.
- KitchenSync
Ebay
Yeah - there's one on at the moment for £25 - which probably isn't much better than mine as it's the same age. I figured someone must sell the bits that are worn.
- randomsquid
- Wear the Fox Hat
Looking at a parts diagram from a shop I've never heard of it looks like they're about £20 the pair.
http://www.apriliagenuineparts.co.uk/co ... e-3653.php
Have a google for rose joints and see if you can see any cheaper ones with the correct ends/thread or pop into your local bearing place with yours.
http://www.huco.com/products.asp?p=true&cat=250 i did get some from this place but as they are near- by i just poped in,,, on my falco it was
the bush in the pedal that let it all woble about
red and black v twin
- KitchenSync
Brilliant!
Thanks Dave - just what the doctor ordered.
Yes - the bush is well and truly whacked as well - so as suggested - a trip to the local bearing supplier might be in order.
Cheers!
Cheers!
Re: Brilliant!
Certainly were for my father in law - just seen him in hospital having had his hip ball-and-socket joint replaced !KitchenSync wrote:Thanks Dave - just what the doctor ordered.
..... been a bumper hospital day today - visiting both my dad and my father in law - fortunately both in the same hospital
