Short oil filter
wayofthedarkhand
Short oil filter
#1 Post by wayofthedarkhand » Tue Mar 05, 2013 2:15 pm
I need one of these. I'm told halfords stock them. What do I need to ask for?
I'm presuming if I waltz in and start talking about an Aprilia Falco they'll think I've gone mad.
Tonyunn
#2 Post by Tonyunn » Tue Mar 05, 2013 2:26 pm
Aprilia 2004 SL 1000 Falco K&N Performance Oil Filter KN-152
I got mine from demontweeks direct via e-bay for £10.52 worked a treat.
Speed Blue SL 1000 Falco
wayofthedarkhand
#3 Post by wayofthedarkhand » Tue Mar 05, 2013 2:44 pm
Well I'm told halfords sell them for £6 so that seems like the best option.
Tonyunn
#4 Post by Tonyunn » Tue Mar 05, 2013 3:00 pm
The KN-152 is the bit that has to match, that is the K&N part number, if you get it for £6 that's really good.
wayofthedarkhand
#5 Post by wayofthedarkhand » Tue Mar 05, 2013 4:26 pm
Champion x312 £7.49 (or similar).
Now I just need oil (used to buy HG's 10/40w for £20) and an oil drain tank (through my old out).
What internal changes to the engine were there between models that allow the newer models to run fully synthetic?
falcomunky
#6 Post by falcomunky » Tue Mar 05, 2013 4:30 pm
Personally, I'd go with 15/50 semi (unless you've been using 10/40 without any problems: Caused clutch slip for me) Silkolene Fuchs.
As far as I'm aware there were no internal engine changes other than the oil filter case getting longer.
Two is the magic number... ;)
wayofthedarkhand
#7 Post by wayofthedarkhand » Tue Mar 05, 2013 4:32 pm
falcomunky wrote:Personally, I'd go with 15/50 semi (unless you've been using 10/40 without any problems: Caused clutch slip for me) Silkolene Fuchs.
I saw a memo from Aprilia to there dealers in was it Germany/Sweden saying that 10/40 should be used in colder climates.
Personally I couldn't care less. I just was the cheapest oil possible that going to last until the next scheduled service.
falcomunky
#8 Post by falcomunky » Tue Mar 05, 2013 4:39 pm
Well, I guess parts of Germany and Sweden would count for a generally colder climate than here in the UK. :smt002
As in most things in life/biking: You pay your money, you get your quality. Cheap oil doesn't have the same additives that the more expensive stuff does and going by recent scandals, you might even be putting boiled horse in yer motor! :smt005
wayofthedarkhand
#9 Post by wayofthedarkhand » Tue Mar 05, 2013 4:41 pm
falcomunky wrote:Well, I guess parts of Germany and Sweden would count for a generally colder climate than here in the UK. :smt002
Might see an increase in BHP :smt003
#10 Post by Aladinsaneuk » Tue Mar 05, 2013 5:42 pm
Some of us believe there was a change around 2001 - bikes from 2002/3 run full synth oil with no problems. The earlier bikes IN THE MAIN need semi synth or the clutches slip
I am not aware of any clutch slipping with 10/40 - indeed aprilia issued a directive to dealers to use 10/40 IF clutch slip was reported with 15/50
I use semi synth 10/40.... And yes I do buy a quality one :)
We do get a discount with opies oils
#11 Post by fatboy » Tue Mar 05, 2013 7:02 pm
I did run on Fuchs 15/50, then changed to Castrol 10/40 Magnatec ( or some silly name)
Conclusion...
now find neutral first time every time, but think I hear a bit more mechanical noise
#12 Post by D-Rider » Tue Mar 05, 2013 10:25 pm
I thought Magnatec was car oil?
Apparently it can be a bit risky putting that in a bike with a wet clutch as the added friction modifiers can cause clutch slip
Cathcart
#13 Post by Cathcart » Wed Mar 06, 2013 6:34 am
I've always used castrol power 1 in previous bikes and I'll use the same in the falco...
Marco Simoncelli.
#14 Post by Aladinsaneuk » Wed Mar 06, 2013 7:16 am
Magnatec is a car only oil though there is a bike version iirv
gazzo
Main bike: Falco
#15 Post by gazzo » Wed Mar 06, 2013 6:45 pm
I always use the Mobil 1 Fully Synthetic Racing 4T 15/50w. I have had the bike 2 years in spring and have had no problems. I have an 05 model although made in 03. I see no one ever mentions this oil, is there future probs if I continue to use?
Gaz.
