Blue Flame cans
gazuk
Main bike: vfr 750ft
Blue Flame cans
#1 Post by gazuk » Sat Apr 21, 2007 11:38 am
My dual port Blue Flame cans have just arrived off ebay. They look good, but I've noticed that the lower port on both cans is blanked off. Is this normal?
When swopping chips around, do people bother with anti static mats and jelly type stuff on the chips (to help witht he affects of vibration)?
Also, my mille sachs shock arrived this morning. It was like christmas day :smt003
#2 Post by fastasfcuk » Sat Apr 21, 2007 1:35 pm
yes thats normal, there just disk's held in with circlips i've got all mine removed. :smt007 :smt007.going back to your mille shock does that fit straight on or do i have to fit the mille linkages :smt017
sabestian
#3 Post by sabestian » Sat Apr 21, 2007 2:16 pm
Re BlueFlames - it's normal. Just bin them :smt020
Re shock - yellow spring needs links, white spring bolts on.
falcomunky
#4 Post by falcomunky » Sat Apr 21, 2007 3:53 pm
Correction; My yellow spring, (and Im sure somebody else on ere has done the same), are using the Falco links without problems. What an improvement! :smt003
Two is the magic number... ;)
gazuk
#5 Post by gazuk » Sat Apr 21, 2007 4:58 pm
I shall be fitting the mille sachs yellow spring with the standard Falco linkages (cos I aint got the mille ones). Nothing to lose, if it doen't work then I'll have to get the linkages.
sabestian
#6 Post by sabestian » Sat Apr 21, 2007 6:06 pm
I'll try that too, then. It'll be 'a bit" weird set-up: Mille swinger and shock, Falco linkages :smt017 :smt003
falcomunky
#7 Post by falcomunky » Sun Apr 22, 2007 10:08 am
Works fine fer me, (though Im sure the RSV links will improve things again), mind Iam only 10/11 stone fully kitted-up... :smt002
