Disc bolts, rear
wayno
Disc bolts, rear
#1 Post by wayno » Mon Feb 04, 2013 8:42 am
I need to change the rear disc bolts as they're looking very tatty now. Does anyone know if these have to be mild steel for the speedo pick up or can they be changed to stainless jobbies?
#2 Post by D-Rider » Mon Feb 04, 2013 9:15 am
Mild steel for the reason you suggest (well whatever steel they make bolts from - isn't it a higher carbon content or something?)
You wouldn't believe the number of people that go and fit stainless or titanium and then complain that their speedo isn't working .............
wayno
#3 Post by wayno » Mon Feb 04, 2013 9:25 am
That was my reason for asking, probolt do stainless or titanium kits (not that I'm willing to pay £103 for a titanium set anyway! robbers)
I figured it would be a magnetic pick up so needed carbon steel bolts. I'll just order a set of OEM ones from some dealer, the head on the ones I have are rusted to buggery.
cheers d-rider.
#4 Post by Aladinsaneuk » Mon Feb 04, 2013 10:29 am
check that the heads are the same as what you are replacing.... ask me how i know about domed head nuts chewing through the sensor....
wayno
#5 Post by wayno » Mon Feb 04, 2013 10:37 am
Aladinsaneuk wrote:check that the heads are the same as what you are replacing.... ask me how i know about domed head nuts chewing through the sensor....
I did come across that story whilst searching for an answer. Sounds like my usual trick.
Been looking for a dealer to get them from, sickens me that most of them want £7.50 carriage to post 5 x screws to me.
#6 Post by D-Rider » Mon Feb 04, 2013 10:40 am
.... or doomed nuts as they were in your case ..............
#7 Post by MartDude » Mon Feb 04, 2013 2:22 pm
Nooj is researching a 'fix' to allow the use of SS bolts here.
#8 Post by D-Rider » Mon Feb 04, 2013 2:33 pm
wayno wrote: I figured it would be a magnetic pick
Certainly not a magnetic sensor - I think it's a variable reluctance sensor.
Cathcart
#9 Post by Cathcart » Mon Feb 04, 2013 5:06 pm
Uh huh. I was wit you up to "a"... Does it send up a pulse to the ecu or another form of signal?
Marco Simoncelli.
wayno
#10 Post by wayno » Mon Feb 04, 2013 5:13 pm
I got that far too, but was too embarassed to admit it, electrickery is witchcraft as far as I can tell :smt073
#11 Post by D-Rider » Mon Feb 04, 2013 5:19 pm
Yes and No
It does generate a pulse but this goes to the instrument cluster not the ecu
#12 Post by Aladinsaneuk » Mon Feb 04, 2013 6:30 pm
Now we have identified something with a pulse that cannot run away, I do believe the hatless one's sex life is sorted .... Well till lambing is over at any rate
Cathcart
#13 Post by Cathcart » Mon Feb 04, 2013 7:05 pm
Didn't I read somewhere that the ecu only sends the speed signal every set time (ie 1/2 sec) as to stop the speedo jumping about? If not then I'm certainly away with it...
What wire colour?
Hoping there's an outcome to this as my rear bolts are a bit "furry" looking.
Marco Simoncelli.
#14 Post by mangocrazy » Mon Feb 04, 2013 7:14 pm
D-Rider wrote:I think it's a variable reluctance sensor.
I have an in-built one of those. I am increasingly (and variably) reluctant to get out of bed in direct proportion to the coldness of the external temperature.
#15 Post by D-Rider » Mon Feb 04, 2013 8:48 pm
Cathcart wrote:Didn't I read somewhere that the ecu only sends the speed signal every set time (ie 1/2 sec) as to stop the speedo jumping about? If not then I'm certainly away with it...
:smt017
Nope - Firstly the ECU has NOTHING to do with it - the speed sensor is ONLY connected to the Instrument Cluster.
However, there will be a strategy to smooth out the speedo and stop the values jumping about - think of it as a sort of averaging
