Front brake disk help please
- ReggieGasket
Hi, I've just swapped my front brake disks for standard (I think) Brembos (second hand). All seems fine, but the nearside brake calliper isn't alligning correctly. The offside is on OK and the wheel is spinning OK. The discs look the same on both sides and the allignmnet looks the same too
. Going by the calliper it looks like the disc should be a few mm nearer the wheel. Any suggestions? I've pushed the pistons back as far as they will go, so it's not that. Thanks guys.
- ReggieGasket
- ReggieGasket
- ReggieGasket
- Falcopops
main spindle is 80nm pinch bolts 22 or 25 can't remember, but ohlins are only 12nm
If it's only the discs you've changed, check for crud/thread lock under the disc mounting face. Make sure the caliper bolts are the right ones etc.
Did you follow the fork alighnment technique when reinstalling the front wheel? Might be all it is.
IIRC you need to tighten the left side pinch bolts, torque up the axle, tighten the right side oinch bolts, loosen the left side pinch bolts, bounce the forks a bit with the brakes on, then tighten the pinch bolts.
Please check the sequence, because I'm nototiously bad at remembering this and although I've done it 3 times in the last 2 weeks, I had to look it up each time.
- ReggieGasket
Isn't that just the radial calliper ohlins forks? I think the standard ones are the same as the other forks - mind you, this is just from memory as I've not got time to check this morning.Falcopops wrote:main spindle is 80nm pinch bolts 22 or 25 can't remember, but ohlins are only 12nm
- ReggieGasket
Success
Finally I'll be able to try the new front tyre
Turned out it was the front wheel not on correctly. The wheel pin wasn't fully inserted, so the wheel wasn't pushed over far enough to the right. I've had the wheel on and off a few times in the past and I've never really realised how easy it is to get it wrong. Thanks for the prompt Falcopops
