Fitting R & G crash protectors
I am just about to fit upper crash protectors (the ones that you have to drill the fairing for). I looked at the instructions last night and it sounds like a bitch of a job. Are the instructions reliable? Does anyone have any experience that I might benefit from before I start?
Alternatively use snopake (correction fluid), saves you buying a marker pen as most work places have the stuff. Put the bolt in the engine/frame hole then mark it up. don't have the bolt sticking out to far though, you'll distort the plastic panel when you offer it up.
Then drill a 5 mm pilot hole in the centre (so that you can see if its inline with the holes)
Dremel with a grind wheel is best (pointed one 1" wide) drilled from the outside on the plastic
I've done 4 bikes that way.
Good luck
Good luck
Ive just moved them onto the other bike and I found it easier to stick the new oil pipe onto the lower hole, then remove the 3 oil tank fixings and push the tank down onto the oil pipe rather than trying to push the pipe onto the already-mounted tank. Its then only attached by 2 or 3 rubber tubes so its easy to force
back onto its mountings.
Its the easy bit compared to drilling the holes
