Heated grips/dead 'alternator'
Guy I bought the Futura from had heated grips fitted, but had them disconnected as he believed that the high current draw on them is what killed the original alternator.
Since I have no idea if this is possible, wanted to ask the assembled Futilari if this was possible.
Wiring mod is reported to have been done although I have yet to have all the panels off to conf.
If this seems unlikely, and it was just a coincidence I may well re-connect for comfort in cold conditions.
- randomsquid
- Wear the Fox Hat
Bloke I used to work with bought an F650 with heated grips and was worried if they were too much for the charging system on his commute. We hooked it up one dinner time and they were only a problem if the grips were on the highest setting, the main beam was on and the motor was at less than about 3k.
If your electrics are generally healthy I wouldn't worry about the grips.
Ok general consensus is should be ok, since I am any pity any way I can test what they do draw, obviously will have to connect them up n turn them on but where would I be able to apply the multimeter to get a usable/meaningful reading.
PS although I have the multimeter, don't have any skill to know how to use it
Keef even with the grips on my scooter with maximum setting it did not flatten the battery or fook the charging system.old git wrote:Ok general consensus is should be ok, since I am any pity any way I can test what they do draw, obviously will have to connect them up n turn them on but where would I be able to apply the multimeter to get a usable/meaningful reading.
Unless there is an earthing fault i can not see the grips causing your bike any issues what so ever.
- randomsquid
- Wear the Fox Hat
I wasn't really being serious in asking what they draw - they should be fine.old git wrote:Ok general consensus is should be ok, since I am any pity any way I can test what they do draw, obviously will have to connect them up n turn them on but where would I be able to apply the multimeter to get a usable/meaningful reading.
