modifying sidestand frame bracket ...
#1 Post by fatboy » Thu Oct 04, 2012 6:18 pm
Has anyone tried this ?
Im asking because as I was offering up the ' honestly guvnor 06 blade stand from eblag'. it seemed to me the biggest problem may be the angle at which the stand is at when its down.
Ideally the stand leg should be at around 45 degrees to where ( the imaginary ) bottom frame rail would be.... but the stand drops to around 55 or 60 degrees, if you get me.
That puts tons of strain on a not that butch to start with sidestand, my stand is bending toward the rear of the bike.
Just wondered if anyone has explored this ? ?
Big thanks Dave for posting me the stand, pm me :smt006
#2 Post by flatlander » Thu Oct 04, 2012 7:01 pm
I had a brand new one and after much head scratching the ace design team at blinkster tech remodelled the structural integrity of the device in such a way that other than applying a drop of 3:1 to the original spring and weeping at the butchered and cast aside Honda shite ( well the money that could have paid for the Rizoma fluid container) Other than that I've never once doubted it
So my advice is you're right IMHO it can end up looking more shiny than the original. Now my Blinkster that's a different story ;)
Re: modifying sidestand frame bracket ...
#3 Post by D-Rider » Thu Oct 04, 2012 7:07 pm
fatboy wrote:Has anyone tried this ?
Yes - you used to be able to buy "Perky's Tilter" to do this
Helps a bit but doesn't solve the problem.
The angle IS the biggest issue but when the angle is changed you need a longer stand.
The US stand and Gixer stand solve the angle and length issues (probably the Honda stand too) and they are physically more robust than the standard stand
#4 Post by blinkey501 » Thu Oct 04, 2012 7:19 pm
I tried fitting one to flatlanders bike and i could'nt get the angle right.
I tried bending the stand with heat applied but when the stand was folded back it looked has though it may catch on the floor when riding and leaning the bike.
After tinkering for a good hour i decided to cut the leg off but keep the honda mounting block and weld a piece of solid bar in its place and used the spring peg plus the rod that you would put your foot against to lift the side stand up and down off the honda stand and weld them to the bar.
Tbh honest it was a bit fiddley but worth the effort in the end.
I don't know if you have ever seen a bobseywoo side stand, but that is what flatlanders stand looked like when completed and does the job well.
On a final note the honda stand is hollow so bending the stand could cause fractures so be carefull :smt002
#5 Post by Aladinsaneuk » Thu Oct 04, 2012 7:54 pm
You just use the leg of the blade stand - not the bracket....
#6 Post by D-Rider » Thu Oct 04, 2012 7:55 pm
Aladinsaneuk wrote:You just use the leg of the blade stand - not the bracket....
And same with the Gixer stand
#7 Post by flatlander » Thu Oct 04, 2012 8:15 pm
Don't care I am very happy with my Blinkster stand :smt003 :smt020
#8 Post by blinkey501 » Sat Oct 06, 2012 5:11 am
So lets get this straight... you spend a load of money on a blade stand which does not fit and have to cut the leg off and weld it to the falco mounting block :smt017
Seems a lot of money and a lot of messing around, I think i am will go in the garage today and cut the leg off my origional falco stand and weld in a piece of solid bar and weld the lugs off the origional to the solid bar and fit it to my bike to see if it fits right and sell blinkeywoo side stands.... :smt017
paddyz1
#9 Post by paddyz1 » Sat Oct 06, 2012 6:18 am
blinkey501 wrote:So lets get this straight... you spend a load of money on a blade stand which does not fit and have to cut the leg off and weld it to the falco mounting block :smt017
That is what i did. I used perkys stand adapter and extended my stand the about 40mm.
#10 Post by flatlander » Sat Oct 06, 2012 8:05 am
I told you that you should! You can use mine as the catalogue model once you've finished polishing and spraying it LOL :smt003
#11 Post by blinkey501 » Sat Oct 06, 2012 10:30 am
I have a perkys stand adapter but you could cut the bar to any length and do away with the adapter completely :smt003
#12 Post by D-Rider » Sat Oct 06, 2012 10:32 am
I've not used a honda stand but I thought that one bolted straight on with no mods
:smt017
slickliner6
#13 Post by slickliner6 » Sat Oct 06, 2012 11:05 am
:smt017
it does :smt017
we were so poor when i was growing up.Dad said "its a good job i was born a boy,at least id have something to play with" ;-)
Sleepyboy
#14 Post by Sleepyboy » Sat Oct 06, 2012 11:35 am
:smt017
it does :smt017
Wot he said :smt017
It can be improved by shortening it slightly but it is not essential
#15 Post by blinkey501 » Sat Oct 06, 2012 2:32 pm
blinkey501 wrote:I tried fitting one to flatlanders bike and i could'nt get the angle right.
My origional post :smt017
