......and so in my usual gung ho way went on to acquire a Gabro chip which I plan to try next again open airbox etc all of which leads me to the point which is Ed / Forza Aprilia has sent me the first draw at his Falco chip. This is one that has been discussed on a couple of few of the fora so ....
My idea was to compare the Gabro and Dr Rossi but I thought that it would be churlish to not share the information now that we have the three to compare together
My thoughts are to use the three one after the other in similar circumstances and report comparative feel for each one. Commuting means I will be using the same routes in similar circumstances and have an "airtfield" section I can use to compare revs etc .
not very scientiofic but then not meant to be as that would open up far too many specific questions and scenarios
So for example :
Dr Rossi
I find this sharpens start up so that the bike starts quicker and needs less choke, I am told it uses some itiming mods. I find that most of the benefit or noticeable difference is from 50 mph upwards and certainly in what I would call the useable speed and power range.
I have "estimated" that the revs would equate to between 7 and 8 k for the 100-110 range and the whole feel is similar to having overdrive on a car . In that it feels like it revs less for the same torque / power.
Acceleration can be deceptive and more rapidly than normal find yourself in licence loosing area if not careful.
It did seem to reduce the sharpness of the roll off when decelerating which can be a little surprising at first. Fuel economy I would say slight improvement even though more looning about appears to take place.
Overall would I buy one again oh yes lots and lots of fun
Anyway just first notes Ill try and do some kinfd of comparison table but int he meantime please suggest anything I should test for within reason and whether it might be of any interest outside of my head
