Rear brake
- Falconihlist
Rear brake
Finally managed to get the rear brake bled through after doing the Mille swap. Nice to have a lever that has 2cm max travel and not 5cm max travel as Nooj will testify to
Black is fastest!
- flatlander
- Falconihlist
..... you mean you've moved it to the position that causes so many problems for the Mille brigade?Falconihlist wrote:Swapped the rear master cylinder to the Mille setup so it is now under the clutch basket and using a Mille footpeg.
- Falconihlist
